Results 1 to 9 of 9
Thread: converter break-in
    Central Florida
    Default converter break-in
    Hey, my initial impressions with the converter are that I can feel a bit of surging at slow cruise and some "grabbiness" when starting out. I'm thinking this is normal and will get better as the converter wears in. Anyone have any experience with this?
    Vendors Andy@Livernois's Avatar
    Grand Blanc, MI/Dearborn Heights, MI
    I personally have never experienced that... Just out of curiousity what convertor is it? I have seen quite a few yanks have this issue, usually requiring a adjustment...
    Livernois Motorsports
    Click here to check out Livernois Motorsports on YouTube
    CNC Cylinder Heads, Rotating Assemblies, Short Blocks, Performance Parts, Dyno Services, Fabrication and Machine Shop Services
    Click here to take a virtual video tour of the shop
    Central Florida
    Quote Originally Posted by Andy@Livernois View Post
    Yank.
    I have seen some issues out of them where it actually is a lower stall then stock. We had an 05 mustang w/ a whipple, 14 lbs of boost, stage 3 heads, comp stage 1 blower cams... This car flashed the convertor @ 2200rpm, stock flashed to 2800 and it was ordered as a custom 3400 IIRC...
    Central Florida
    Doesn't feel like that type of thing, just feels a little grabby. Its only got about 10 miles on it though, might be partially just me getting used to it. So far I'm only a little concerned, will put a few miles on it and see what happens.
    definitly keep us informed...
    Senior Member G8GTlawride's Avatar
    Titusville, Florida
    I've had high stall speed converters before, but not on this type tranny, only the GM Turbo 400. A local company in Rockledge Fl. who built the tranny and the converter. It did not need a break in at all. Just install and mash the gas.
    Maybe they're different now, I don't know. But never experienced what you are describing. All they are are large fluid cuplings, I can't see where anything needs breaking in.
    any updates?
    Central Florida
    Yea, sorry. It wasn't the converter after all, Tune just needed tweaked.
