need gmlan wiring diagrams
Does anybody have wiring diagrams that shows the gmlan circuit and where the pins are on the BCM? Pretty sure I've found where they are on the OBDII port and I have ECU/TCM diagrams. Any assistance with how to troubleshoot the system past checking resistance would be greatly appreciated as well.
Fwiw I'm not getting a cel on the dash but I do have abs fault and traction control off messages that come up immediately even after disconnecting the battery for a while. After letting the car run about 7 minutes I get contact dealer and the tach/speedo/temp/gas indicators ask drop to zero.
A maxysis scan tool was able to find several codes including a u0073 code that comes back immediately after deleting all codes.
Also this is a manual swap that has been running fantastic for about a month or more. And was running decent for a while prior to that.
- You may not post replies
- You may not edit your posts
Forum Rules
