Results 1 to 8 of 8
Thread: Crankshaft pulley
    Jun 2013
    Default Crankshaft pulley
    What’s the stock replacement crankshaft pulley part number? Is it av delco 12675715? I dont want an underdrive pulley as I use the car for a daily driver. It started to wobble today figure I will replace it. Any tips on install? Should I buy a puller or can I rent one from the local parts store
    1985 Buick Grand National w/87 drivetrain
    Quote Originally Posted by turbojitsu View Post
    Call Greg at Pace Performance. He will get you the right pulley with a G8Nation discount.
    I ran an underdrive pulley on my GT for 5 years as my DD. Absolutely NO issues.
    Greg Was at Pace for sure though! He's the best.
    Sep 2009
    VT
    The parts store will have loaner puller. Search this or the other board for the puller detail. It's a three jaw. You will also need a install tool. Several varieties from DIY to ebay. Don't try to pull it on with the bolt - strip the crank treads and you are done. Will need mongo torque wrench -if using arp it's set to 240ftlbs. Do not reuse the factory bolt, it's a torque TTY. New factory or ARP.
    Removal:
    OTC 6667 Harmonic Balancer Puller (Amazon)
    or GGT-120
    This puller is often available for loan at AA or AZ
    install: Hawk LS Series Harmonic Balancer Installation Tool ( This can be made easy enough if you have lowes / fastenal local.
    flywheel holder: kent-moore J-42386-A or CAR SHOP CSP2344 LS1 2 3 LSX Engine 4.8 5.3 5.7 6.0 6.2 FLYWHEEL LOCKING TOOL $39.95 BUY ONLINE or Flywheel flexplate holders - on - LS1TECH
    Sport /Premium
    Jun 2013
    I noticed the wobble yesterday after the drive in to work. It was noticeable from inside the car. I drove the car home and did another inspection and couldn’t see it this time. Is it possible for the symptoms to come and go?
    Jul 2010
    Castle Rock, CO
    Yes...mine would wobble and then stop. When it started to make noise tho...it never got better. Replace it early and be done with it.
    09 G8 GT in Stryker Blue
    Mods
    Go: Vararam CAI, SLP Headers, Magnaflow 12468 mid-muffler & PM-FL Axlebacks. Tuned by MAC Autosports of Parker, Colorado. FE3 Shocks N Struts.
    Show: Little Trees US Flag Vanilla Scented Air Freshener; SLP G8 Firehawk wheels; tinted windows
    The Track
    Best 1/4: 13.969 @ 102.70 @ Pueblo Motorsports Park, w/ DA of 3921'.
    Jun 2013
    Thanks for the help guys it’s always appreciated. Does anyone have the part number for the bolt that holds down the crankshaft pulley?
    ARP makes one. Use that. Again, Greg Was can hook you up.
