Results 1 to 4 of 4
Thread: Map sensor Kpa readings from dashhawk
    Default Map sensor Kpa readings from dashhawk
    While im idling in park i get a reading of 40kpa. When my car is at wot should i have a manifold pressure of 100kpa? Or would that happen only in a perfect condition where air/fuel ratios are perfect? I thought i read somewhere that anything above 100kpa was a positive pressure, meaning there is boost above 100kpa
    What can the 40kpa tell me about my car? What readings are you others getting when idling in park? I have a rotofab intake.
    2008 G8 GT liquidred Premium/Sport Package
    Rotofab cai, HSRK, 160 T-Stat,AR 1 7/8 Headers w/high flow cats, vms tcm/ecm tune, Pypes Violator muffs, some GRRRR8 mods
    Next: non dod cam package via livernois motorsports
    Next after Next: Nitrous
    Am i not making any sense at all? Sorry if its a strange question, im still a newb when it comes to trying to learn about cars. Just trying to make sense of some of my dashhawk readings. Most of them i have no idea what they are for.
    VIP Member Blackrider's Avatar
    Victoria B.C.
    Quote Originally Posted by liquidred1 View Post
    40 kPa is telling you you have a vacuum in the intake manifold, and 40kPa is normal at idle.
    Intake manifold 40 Kpa = low pressure, atmospheric pressure 101 Kpa = High pressure, high pressure moves to low pressure = Vacuum.
    At WOT You want to be as close to the current atmospheric pressure as possible. A little trick, turn the engine off and the kPa reading the dashhawk gives you is the current barometric pressure.
    If you're seeing the same intake manifold pressure as barometric pressure that would be telling you there is no restriction from the filter to the sensor which is what you want.
    kPa is just another pressure unit
    101 kPa = about 14.7PSI which is also considered "1 atmosphere" as thats the pressure at sea level.
    So if you see anything over the current atmospheric pressure you are as you said seeing boost.
    2008 MazdaSpeed 3 - A few Mods
    2009 Panther Black G8GT -
    VMS ECU/TCU Tune, Vararam Intake, FasterProms Ported Intake Manifold & Throttle Body, Doug Thorley LT's mated to a Magnaflow catback with Magnaflow Spun Metallic Cats, & Powerbond UD Pulley
    G8 driving Jarhead rclinton's Avatar
    Jacksonville, NC
    I'm in the same boat as you, trying to figure out all the information the DashHawk is telling me. Reading kPa vice PSI isn't helping. Glad I have a unit converter on my iTouch.
    2009 Pacific Slate Metallic G8 GT with hacked Atari gages. Pioneer F500BT GPS/Bluetooth. Mods: I can not confirm or deny the existence of modifications on this car.
