Results 1 to 5 of 5
Thread: Trim removal
    VIP Member bryand's Avatar
    Apr 2013
    Sheridan, AR
    Default Trim removal
    Is there any way to remove the 4 window moulding pieces along the top of each door without breaking any clips? I guess I'm asking is there any kind of special tool or anything made for this?
    2009 W/H G8 GT
    Jun 2012
    I removed mine once to dip, without breaking most of the clips. It took a lot of time and care, mostly with a flat blade screwdriver. It's not easy.
    VIP Member donkeyGT's Avatar
    Dec 2010
    Jenison, MI
    No special tool I'm aware of but like cstmg8 stated time and care and maybe wrap the end of a small flat blade with a little tape to protect your paint. I removed mine to replace with black ones from Australia. I'm pretty sure you can't get replacement clips so if you break very many you will have to replace the whole moulding. GL
    Jun 2012
    I'd go pick up a cheap set of plastic trim removal tools. I got mine at Harbor freight for around $5
    Jan 2010
    Need alot of patience. don't rush or force it or they'll break.
