Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: larger intercooler and bigger pump for maggie
    Beyond Help Darkmanx's Avatar
    ft lauderdale fl
    Default larger intercooler and bigger pump for maggie
    Has anyone installed a larger heat exchanger or bigger pump? Im alookimg into installing a jabsco pump like the ctsv guys
    Sep 2009
    VT
    LSA blower here. Running zl1 IC and gt500 ic cooler, 2 in thick version with zli pump. works ok for me. Chatter on ctsvowners about zr1/gt500 and merc pumps.
    http://www.lingenfelter.com/LPEforum...esting-results
    Sport /Premium
    ft lauderdale fl
    Got any pictures of the fitment?
    Sep 2009
    VT
    the final install had the nipple on the backside
    pump mounting
    Sport /Premium
    ft lauderdale fl
    Bout to buy a jabsco 29gpm pump. You running 2 coolers?
    Sep 2009
    VT
    yes, in series. do your homework on the pumps. Pieberg CWA-50 seems to have all the buzz now.
    Sport /Premium
    Pearland, TX
    Are there before/after tests of IATs?
    I climb to 140-145 in the Texas heat and basically settle there, but it recovers to normal in 30ish seconds of coasting...
  8. Thanks 805G8GT thanked for this post
  9. #8
    Friendswood, TX
    Great topic! I'm Houston and need the better cooling
  10. #9
    Friendswood, TX
    I've got a 2 core with fans off an 2014 Shelby that I want to retrofit. ...... I can sure learn from you guys
  11. #10
    ft lauderdale fl
    alot has happend since this thread, i switched to a lsa, installed a icebox in truck and the end of the week i will be installing another heat exchanging in series with the maggie
