Results 1 to 4 of 4
Thread: G8 60' Drag Times Records
    Addicted Member bracketracer's Avatar
    Dane, WI
    Default G8 60' Drag Times Records
    We all know that the key to quick ETs for our big 'ol G8s is getting them off the line. The quicker your 60' time can be, the quicker your ETs will be. I decided to compile a list from a variety of places to see who has been the fastest. If the Admins could make this thread a sticky, I would appreciate it. Here is a link to the Google Spreadsheet:
    https://docs.google.com/a/bergstroma...nuQ/edit#gid=0
    If you are not on the list, and want to be, please add a response with a copy of your timeslip, and post your screenname, your 60' time, and the type (street, drag radial, or slicks), brand & size of your tire. This info could help others when making the decision on how to go faster.
    Joe Morgan, G8 GXP Registry Organizer, G.O.N.E. Organizer
    2009.5 G8 GXP WH 6M onyx/red no roof 12.921 @ 108.89 BONE STOCK! (then), (now) 12.344 @ 110.92 with 1.688 60' at 766' DA, PB with new cam & tune 12.191 @ 112.35, 2:59 Second Lap Time Road America (Goodyear RS-As & Hawk HP Plus pads with stock rotors), 143.1298 mph NoFlyZoneMidwest 2017 1/2 mile into 20 mph headwind. RACECAR NOW RETIRED. All of these are final PBs.
    VCM OTR CAI, HSRK, Heater Hose Relocate, custom street/dyno tune by oldskoolgp, Comp Cams 224/228 .581"/.588" 112 LSA cam, LS7 lifters, PAC 1219x springs, Monster LT1S (C7 Corvette) Clutch kit, Katech C6 Hvy Dty Master & Slave Cylinders, Camaro 1LE Diff with 3.91 gears, Kooks LTHs, Solo Hi-Flo Cats & Connector Pipes, Solo Mach Balanced Catback, BMR Toe Rods, Trailing Arms, Cradle & Diff Poly Bushings, 2017 Chevy SS front & rear Brembo calipers and rotors.
    Senior Member morpheousssv's Avatar
    Perth W/Australia
    Morpheous, auto 6L80 1.547 60' - Mickey Thompson ET - 275 40 17. Note : Had to get tyres real hot to stick
    11.255 @ 119.95 MPH 1.54 60' (N/a) updated 18/12/2015
    10:87 @ 127.73 MPH 1.5 60' (N2o) updated 13/01/2016
    Dane, WI
    Updated. Thank you!
    Senior Member Todasi's Avatar
    Dec 2009
    Small Town, Mi
    Todasi 285/30/19 Continental DWS 1.780
    -Chad
    VCM intake, Kooks 1 7/8 LTH, Kooks cat and mid-pipes, Hooker Maxflo muff,
    223/231 .625 .622 RCR Cam, RCR heads, intake and TB, .
    BMR swaybars, Koni shocks, Eibachs, Lovells strut bushes, BMR rear LCA, rear cradle inserts.
    Camaro Brembo's F & R, V701 rims 255f/285r 11.77 @ 118 on street tires
