Results 1 to 5 of 5
Thread: Race star wheels
    Jan 2013
    Default Race star wheels
    I just ordered some race star wheels and I've been reading up on what people have done to make them work. So far I've gotten 2 different answers. One says to change the studs and another says to change the washers and lug nuts...I need help deciding and the easier way
    08 g8 gt- 1 7/8 kook long tubes, 3 in exhaust, slp underdrive pulley, ported manifold, ported tb, vararam cai, 4 in maf, 3200 circle d stall, 3.45 gears
    best 1/4 time= 12.74 60ft=2.1 mph=112 on stock street tires
    Oct 2009
    Webster, NY
    1 Vote for NOT NEEDED.. But you already knew that Have been running with stock studs for 2 years and no issues. Buy lug nuts and washers and be done.
    2008 NA G8 GT
    1/4 mile = 10.93 @ 123
    60' = 1.47
    DA = 500
  3. Likes RedSexy liked this post
  4. #3
    Jul 2013
    Grand Blanc, MI
    True, 100% Direct Bolt on with the Supplied washers. Boxes said 5x120mm on them. Fit Perfect. Call LB Davis @ RaceStar if you need help making sure you order the correct set. I called him, got the correct info and then ordered from Summit.
    2014 Chevy SS - RedHot
    #115 0f 291 Built as optioned
    11.217@124.89 Personal Best
  5. #4
    Senior Member scorpion's Avatar
    Jun 2012
    Armpit of America virginia beach
    What set did you get? The last time I talked to them the black wasn't offered in our offset and size
    2009 LR G8 GT
    Varraram intake, LS7 maf, SLP underdrive pulley, granatelli 0 ohms resistant 10.5 wires and coil packs, PYPES 1 3/4 tri y long tubes, OBX x pipe no cats, flowmaster 44 with 4" quad tips, camaro 3.45 rear end, BC coilovers, BMR lower control arms, BMR tow rods, BMR trailing arm, BMR subframe connectors, BMR tunnel brace, BMR strut tower brace, BMR front sway bar, BMR rear sway bar, spyder rear tail lights, powder coated black camaro rims
    6.2L engine swap
    Rick Crawford special
    Ported polished and milled heads (11.6:1) with LS9 valvetrain, Rickifast intake, Rickifast throttle body,DOD delete,CTSV racing lifters, 111 lunati cam, 3000 triple disk coan stall
    2011
    yellow ctsv brake upgrade
  6. #5
    Jul 2013
    Grand Blanc, MI
    I got polished. LB told me both were available. Only got the polished since I have chrome trim on the car.
