Hi all,
I have SLP lowering springs on my car. Last year I changed out the rear springs and put the stock springs back in, so now I have lowering springs in the front and stock springs in the back. I figured that this would help with weight transfer allowing it to squat hard. I thought the more squat the more pressure on the rear tires, which would result in better grip. Reading around it appears that this may not be a good idea and may be slowing me down out of the hole. What are you opinions on this? Should I put the rear lowering springs back in? Again, this is question is only for drag racing purposes, and not cornering.
Thank you
Jon
