I know there are a ton of HSRK threads floating around but I didnt find out the specific info I was looking for.
I am looking at purchasing the Casper kit #108165 http://www.casperselectronics.com/st...oducts_id=1137
Is the harness long enough to place the new IAT sensor in the partitioned area of a Spectre intake close to the filter? Also is that the correct part number that I need from Casper?
Second, what do you think about this IAT sensor on ebay? http://www.ebay.com/itm/TS10072-AX32...6f385f&vxp=mtr
It is significantly cheaper than the ones from local parts stores...which are closer to $18 plus tax. If the ebay one looks good enough im going to try it out. I figure they are all probably manufactured in the same factory in China and boxed up differently for different parts stores.
Is this all I will need besides a rubber grommet for mounting the new sensor? What size grommet will I need?
