Results 1 to 4 of 4
Thread: Fuel Rails- parts list and notes
    Central Florida
    Default Fuel Rails- parts list and notes
    Parts list and tips for fuel rail install:
    Not intended as full tutorial although it may evolve. Will post pics when I can.
    AEI-14115 - Aeromotive Fuel Rails (1)
    AEI-15607 -Fitting, Straight, Male -8 AN to Straight Cut Male -8 AN O-Ring (4)
    AEI-15637 - Fitting, Hex Head Port Plug, -8 AN O-Ring, 1/8 in. Female NPT Port (1- if installing fuel pressure gauge)
    AEI-15618 - AN-08 ORB - Slim Line - Port Plug (1- if NOT installing fuel pressure gauge)
    Note- if you don't plan on a fuel pressure gauge now but think you might later, use fitting AEI-15637 along with a 1/8 NPT plug such as Aeroquip AER-FBM3685 . Be sure to use thread sealant on plug or on fuel gauge sending unit.
    AEI-15118 - Quick connect fitting to go from factory fuel line at firewall to AN line
    Hose ends- You'll need 3 AN -8 90 degree hose ends and 1 45 degree hose end. Use whatever brand you prefer but don't cheap out on these.
    Stainless braided hose- you'll need about 2 feet of -8 hose, get 4 feet to allow for screw-ups. Get any brand you prefer but get good stuff.
    You'll need a tool to disconnect the factory fuel line. There's lots of options, just be sure you get 3/8. I used this one: http://www.toolfetch.com/Category/Au...ols/KD3321.htm
    You'll also need to know how to make AN lines. It can be tricky but generally they go together pretty well. Here's a decent tutorial:
    http://www.project-mayhem04.com/AN%2...0How%20To.html The only thing I don't like about it is that I prefer to use thread sealant as opposed to teflon tape. Jegs has some cheap: http://www.jegs.com/i/JEGS/555/28011/10002/-1 or, to make life really good, pick up a kit with hose assembly lube and sealant: http://www.jegs.com/i/JEGS/555/28010/10002/-1
    I recommend sourcing the Aeromotive parts (part numbers start with AEI) through Livernois, good prices and fast shipping. You can also get all of this stuff from Summitt and/or Jegs.
    WARNING- do not substitute other brands for the Aeromotive fittings without careful research. These are special O-Ring boss connections, not pipe thread. No sealant required on these, just a drop of oil to lube the o-rings. You'll be using 3 of the AEI-15607 fittings on the rails and the other one on the AEI-15118 fuel line adapter. The fittings are a bit pricey but well worth it.
    Expect to pay a bit over $300 for this project if you do the work yourself.
    G8erator '02 ws6's Avatar
    White Deer, TX
    Good info. Looks like you've dimished any possibility of having your fuel system being a hindrance w/ your Procharged setup
    BlackBerry8830/4.2.2 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104
    Central Florida
    Seems the line making tutorial I linked is gone. Here's another:
    http://www.clubcobra.com/forums/all-...d-lines-2.html
    Stuck.
