Results 1 to 10 of 12
Thread: Staggard Fitment: effect on performance
    Beyond Help jbradsh1's Avatar
    Smile Staggard Fitment: effect on performance
    I mentioned in an earlier post that I'm considering getting 18x8 front and 18x9.5 rear TSW wheels along with 245x45x18 and 275x40x18 tires. Anyone know how this will affect handling? Off the line traction at the track? Ride quality? Noise, with Michelin Pilot Sport A/S tires? Thanks in advance.
    Also, any problem with proper fit, assuming front wheel offset of 40mm and the rear's at 45mm?
    Addicted Member PantherGTBlack's Avatar
    Jan 2009
    LaGrange/Ft. Wayne, IN
    I know when I did some testing for TireRack at South Bend I had a 295 on the rear and I noticed that it made the car have a slower turn-in rate, if that makes sense to you. I would say a 275 rear would be just about perfect, you will get good straight line traction and it shouldn't affect the turning rate too much.
    2010 Camaro 2SS/RS, Summit White. M6 some mods.
    2010 VW Jetta TDI Cup Edition, Red. 42 mpg avg!
    2010 Kawasaki Z1000....many mods. ITBFST-R
    (Tragically gone) 2008 G8 GT Black on black, Prem., sunroof.
    Sugar Land Texas
    You should be using a 275/35 on the rear. Sprung weight does effect performance, so the heavier the wheel is it can cost a little ET, but it is offset by the added width for better traction.
    Everything you guys said makes sense to me. Just so you'll know, the 275x40x18 has the same diameter as the 245x45x18 tire, so the ride height will be the same. The unsprung weight increase with bigger tires and wheels I'm a bit concerned about, although the Michelin tires I'm looking at weigh 27 lbs. & 30 lbs. (front to rear), so that's OK, I just don't know the weight of the TSW wheels yet ... compared to stock. I'll find that out tomorrow. Never driven a car with staggard fitment is why I was asking. Thanks.
    Clarks Summit, Pa.
    Quote Originally Posted by PantherGTBlack View Post
    What wheel and offset did you use to fit a 295? What tire?
    19x10, 55 offset?
    Thanks?
    Plastic Cuttin' Bad Ass!
    Jan 2009
    19x10, 55 offset?
    Thanks?
    19x9.5 with a +35mm offset...it didn't stay on the car as you can tell by my signature. We tried that just to test how big you can go. It looked mean as hell that way but they rubbed like a mutha. I'm currently running a 255 on a 9.5" wide rear with a +45mm offset and no rubbing. I know for a fact I can go larger than that. I had rubbing with a +35mm offset on a 9.5" wheel with a 255.
    The 295 tire was a BF Goodrich KDW 2, I think that is the right name. Regardless it is the one with the crazy tread pattern. I'm going to go back to these for my next set of tires. Probably run a 275 so it doesn't affect the handling too much but will still get good straight line traction for the cam, etc. that I want to put on in the near future.
    Beyond Help p71's Avatar
    A-town junior, TX
    It is just KDW, tire rack adds the 2 to distinguish the new from old tread patterns. Badass tires regardless.
    OP: wider rears contribute to increased understeer.
    Your best bet is to go with wider rears that weigh less than stock so the problem Charlie mentioned is negated. also add a nice heavy set of subs to the rear to shift weight balance that way to counteract the understeer and you are good. Or if sound systems are not your thing, get some adjustable sway bars.
    11 Mopar 11 Charger
    11 Ram 1500 White Crewcab Hemi 4x4 Sport TRADED
    10 F150 Raptor Black 5.4 Supercab TRADED
    09 GT Black Premium Sport TRADED
    Mods: Livernois Stage I Kit with ported intake and TB, Livernois Tune, New Era OTR CAI, UDP, Kooks 1 7/8 catted LT, GXP Front end conversion, GXP mufflers, GXP rear diffuser, VMR VB3 19x9.5, Nitto Invo 275s, TMA 3202, 2 JL Audio 12"s, Limo tint.
    Upcoming Mods: GXP brake conversion, DBA rotors, Hawk pads, BMR Subframe Connectors and Trailing Arms, Pedders XA Street system, It is good to have a plan.
    08 GT Black Premium Sport RIP
    2 JL Audio 12"s
    Clear Lake, IA & Naples, FL
    You can change the steering feel with tire pressures. My 285's feel great at the higher recommended pressures in our manual. Since I'm an old foggie, propably best with more understeer!
    Confused, Dazed & Verklemp
    Smile
    Quote Originally Posted by Rob Moser View Post
    Good point, but you know, power induced oversteer will get your heart rate up, in case you haven't been getting your exercise in!
    Devil's Advocate Ktlplxm's Avatar
    Nov 2008
    Charlotte, NC
    Another thing to consider, is that the 295 optimally shouldn't be on anything smaller than a 10", a 10.5" is preferred. When the sidewall is pulled in that much, handling is almost always compromised in some form or another. A perfect example is when we were doing skid pad test on the Nitto NT01's. When we initially had the 315 on a 10 inch wheel the handling left a little to be desired, once the same tire was swapped on to a set of 10.5, lateral G's picked up noticeably
    Winning may not be everything, but its still better than losing
    I don't know you. I don't know what have done. If you are looking to talk up a race for 3 hours, I can tell you I don't have the time. But what I do have are a very particular set of parts; parts I have acquired over a very long career. Parts that make me a nightmare for people like you. If you go home, that'll be the end of it. I will not look for you, I will not punk you. But if you don't, I will punk you, I will race you, and I will embarrass you.
