Results 1 to 9 of 9
Thread: Stability control is off and stuck off
    Addicted Member Edsel1134's Avatar
    Nov 2012
    Default Stability control is off and stuck off
    So was sitting in my car listening to music.. I hear something look down and my car says Normal for the shifting.. I was like O_o???? Then nothing.. Well went to class came out got in my car started it and sat there for a second and my stability control turned it's self off... And is not responding to the button.. Both heated seats are working.. Idk what to do.. Pulled the battery out for now will install it again later.. No codes nothing :/
    Sugar Land Texas
    I have seen this a lot. Deep water, snow etc can cause an intermittent issue. If it is not that you will need to test with a Tech 2 or hi-end scan tool to access ABS and then you can get codes/data.
    Once you get a code, post it and I will let you know what to do.
    Nov 2012
    Kk will do and it was raining today.. And no codes at the moment just says stabilty control off.. Like u just hit the button
    Nov 2012
    So... Put that battery back in and everythin is fine? Guess I'll update after I actually drive it more
    Senior Member Tulsa GT's Avatar
    Nov 2009
    Tulsa
    I had similar issue but think unrelated.
    Will share anyway.
    My TC would turn off intermittently along with a dtc of injector 5 circuit open. Turned out with magnacharger, injector adapters, etc, coil bracket was pressing on injector (adapter) causing it to lose contact, which was sending a misfire code, which disables TC. Most of this is per Andy at livernois motorsports btw. Replaced injector adapter, adjusted coil bracket, and all is well this far.
    LR 09 GT Sport/Premium Onyx/Red
    In: Sunroof, V1/blendmount, Weathertech, Holden console lid, autodim, VIM, Nuvi 765t, Red Shifter & Wheel, Polk ,Kicker, backup cam, BT, Homelink
    Out: HSV GTS 20", Rebadged, GXP Diffuser, 35w 5000k HID, Sharkfin, LED's in progress
    Performance: TVS 2300, Livernois 2C, DOD Delete, BAP, Rotofab, Kooks, Corsa, HSRK, 3.27 Rear245/285 Pilot Super Sport, King/Monroe, BMR sways, SFC's, & Tunnel Brace, Spohn rear arms, Pedders bushings, '11 CTS-V Brakes, SS lines
    Nov 2009
    Tulsa
    Actually just remembered...
    Also had this issue once before when I had toe arms put on and only had rear alignment done bc I'm not smart.
    Everyone knows in these cars, that if you do rear alignment, must then do front.
    So, with total alignment off TC became disabled, at least so far as I understood.
    Just another instance where TC turned off by itself and would not turn back on.
    Nov 2012
    Yeah it is strange.. It's fine now that the ECM was reset due to battery removal for more then 15 min.. Dunno maybe he was just moody
    Mahopac New York
    I had this exact issue. Turned out to be the ABS Right wheel sensor harness. Seems it is exposed to elements and the connections can carode. Since the stability control relies on the input from ABS, once a ABS sensor gets a fault, it turns off stability control
    08 GT MGM Onyx/Red Premium
    Winter 225/55/17
    Summer 245/40/19
    RotoFab
    Maverick Man CF Spoiler
    Nov 2012
    Yeah it's fine now I dunno
