Results 1 to 7 of 7
Thread: Final Drive Ratios from 3.45 to 3.73
    Oct 2009
    Webster, NY
    Default Final Drive Ratios from 3.45 to 3.73
    I know there is a formula out there but I cant seem to find it. I know what the final drive numbers are for 3.45 gears in my car, but how do I figure out what the numbers are for 3.73?
    3.45 final drive gears
    1st - 12.98
    2nd - 7.62
    3rd - 4.94
    4th - 3.71
    5th - 2.74
    6th - 2.16
    3.73 final drive gears
    1st - ?
    2nd - ?
    3rd - ?
    4th - ?
    5th - ?
    6th - ?
    Thanks
    Jon
    2008 NA G8 GT
    1/4 mile = 10.93 @ 123
    60' = 1.47
    DA = 500
    VIP Member G8 GT V8's Avatar
    Fairfield, Ohio
    Just find each gear ratio of the trans and multiply it by the differential's gear ratio.
    Marty
    G8 gone, but not forgotten...
    Oct 2009
    Webster, NY
    Quote Originally Posted by G8 GT V8 View Post
    Alright. How do I find each gear ratio of the trans though? I tried looking that up as well
    EDIt:
    Is this the trans gear ratios?
    The 6L80 (and similar 6L90) is a 6-speed automatic transmission built by General Motors at their Willow Run Transmission plant, in Ypsilanti, MI. It was introduced in late 2005, and is very similar in design to the smaller 6L45/6L50, produced at GM Powertrain in Strasbourg, France. It features clutch to clutch shifting, eliminating the one-way clutches used on older transmission designs. In February 2006, GM announced that they would invest $500 million to expand the Toledo Transmission plant in Toledo, Ohio to produce the 6L80 in 2008.
    Gear ratios:
    1------ 2----- 3--- 4----- 5---- 6---- R
    4.027 2.364 1.532 1.152 0.852 0.667 3.064
    2008 NA G8 GT
    60' = 1.47
    DA = 500
    Cambridge, MA
    2009 Pontiac G8 4dr Sdn GT
    Transmission
    Drivetrain: Rear Wheel Drive
    Trans Order Code: MYC
    Trans Type: 6
    Trans Description Cont.: Automatic w/OD
    Trans Description Cont. Again: N/A
    First Gear Ratio (:1): 4.03
    Second Gear Ratio (:1): 2.36
    Third Gear Ratio (:1): 1.53
    Fourth Gear Ratio (:1): 1.15
    Fifth Gear Ratio (:1): 0.85
    Sixth Gear Ratio (:1): 0.67
    Reverse Ratio (:1): 3.06
    Clutch Size: N/A
    Final Drive Axle Ratio (:1): 2.92
    http://www.pscars.com/gallery/2009/P...GT_297488.html
    Oct 2009
    Webster, NY
    Ok thanks. So then I would multiply each of those numbers by 3.73?
    EDIt: I dont see how multiplying everything by 3.73 would be correct. According to this site, the gear ratios for 2.92,3.27, and 3.45 are as follows
    ------2.92----3.27----3.45
    1st - 4.02 -- 3.23 -- 12.98
    2nd - 2.36 -- 3.23 -- 7.62
    3rd - 1.53 -- 3.23 -- 4.94
    4th - 1.15 -- 3.23 -- 3.71
    5th - 0.85 -- 3.23 -- 2.74
    6th - 0.67 -- 3.23 -- 2.16
    2008 NA G8 GT
    60' = 1.47
    DA = 500
    Senior Member hivoltagedriver's Avatar
    Sep 2011
    Owasso, OK
    Here is a cool calculator that you can use to play with ratios, rpm, and speed...
    http://www.f-body.org/gears/
    To calcualte your final drive ratio in each gear, you just multiply the transmission ratio for that gear with the rear gear ratio that you are running.
    '09 PSM G8 GT w/ Premium & Sport packages.
    Go: Kooks 1 7/8" LTs, catless mids, Corsa, VCM OTRCAI, Rick Crawford's magic intake and ported TB. 12.64 @ 113.5mph, 1.99 60', -70' DA.
    Whoa!: CTS-V/ Camaro 4-piston Brembos, Hawk pads, DBA rotors.
    Show: 4300K HIDs, LED fogs, VG Sharkfin, GXP diffuser, 10% tint, debadged, Eibach drop springs, CTS-V wheels.
    Fairfield, Ohio
    Quote Originally Posted by JonnyG2132 View Post
    That table is messed up...
    Sent from my DROID RAZR using Tapatalk 2
    Marty
