Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: P0171/P0174 Lean code causing issues
    Scranton, PA
    Default P0171/P0174 Lean code causing issues
    Hello all,
    I am wondering if I can get some feedback. I recently had my car built by RPM and they did a cam, stall, etc..and the car did 430/400 on 93. The car has been running fantastic, besides a sporadic P0171 sometimes P0174 code. I usually reset with my aeroforce and continue. I looked into it a bit more and read it could be a vacuum leak. I looked under the hood at all hoses, and saw this..I couldn't see it with my rotofab covers on..
    I plugged it back in, and reset the code..And went for a ride. As I was making a left hand turn into a gas station, the car lost all power. This happened a few more times at red lights. I am not sure what to do now, if I should unplug what was unplugged..and get retuned?
    Just seems weird that this happened once I plugged that connection back in..sorry, I'm technologically stupid..I don't know the exact terminology
    Thanks in advance.
    Current - 08 C6 Vette, Tons of CF, TVS2300 + AHR + ID850 = 505WHP
    Former - 09 G8 GT, LRM. Custom Flowmaster Exhaust, Roto-Fab carbon fiber everything, VMS Tune, Pacesetter Catless, Pedders Springs, MM CF Spoiler, Flip 2 tone tails/grilles, Evolution Auto Designs Bumper, HIDs, Forgestar F05 19'' Staggered on KDW2, SS Brembos, Demon8Designs gauge pod + 3 Aeroforce, 430WRHP/400TQ
    Daily - 12 Hyundai Azera hopefully to be replaced by a Chevy SS!
    Mostly lurk, find me on Facebook: http://www.facebook.com/jsquizz
    That's the breather to the intake manifold. If they did a cam that should be blocked off and that line ran somewhere else, if I'm not mistaken.
    Scranton, PA
    I will try unhooking it and see what happens.
    Apr 2010
    Ocala, FL
    That line hooked from back driver side valve cover to front passenger sde valve cover if I'm not mistaken. Even with a cam all those pcv lines had to be reconnected
    2008 G8 GT
    Rick Crawford Tuned
    663/596 Rwhp rwtq for now....
    10.87 at 133 1.59 60ft
    Sugar Land Texas
    If they tuned it with that line off it would effect your idle tables as they added or took away fuel to make up for a vacuum leak
    Scranton, PA
    Either way It looks like I'll be needing a retune.
    Beyond Help DavesG8GT's Avatar
    Jan 2010
    Birmingham AL
    Yup that port should have been capped with a DOD to non-DOD cam swap. I think the line that used to run there now runs to the LS2 valley cover port, but I'd have to pop my hood and look to know for sure. My memory is fuzzy.
    New (cheap monthly payment car, lol): '12 Candy Apple Red Mustang GT 5.0 6MT, stock for the time being
    **SOLD **
    White Hot '09 G8 GT, Pat G tune, Pat G cam (.634"/.608", 223/230, 112 + 2), G8-4-Speed ported & milled heads, "ram air" intake, & ported TB; Reckart 90mm MAF/LS7 card, HSRK, DT headers, Rotofab, Magnaflow CB, H & R springs, stock gears & stock stall, 11.865 @ 120.32 mph, 1.941 sec 60'
    Under C is the PCV valve.
    If you have an AFM hardware delete, with new replacement LS2/LS3 valley plate, then C will be capped off.
    Otherwise it remains as the exit point from the crankcase for foul air from your engine.
    D is the connection point (vacuum) on the intake manifold where the foul air line connects. The same point is used no matter what valley plate or catch can you use.
    PCV foul air line C-D should always be connected unless you have re-routed the foul air thru a catch can or have an AFM hardware delete with LS2/LS3 valley plate.
    Scranton, PA
    I do have a catch can.
    Scranton, PA
    It was simply unhooked not capped off.
