im looking to add 1/2 inch or about 13mm to the rears. where is the cheapest place to get longer studs? motorsports-tech and adapterkings dont make any adapters less than .75 inches thick. :/
longer studs can be bought from crazy paul in australia. I have them on the front and they were 110shipped for 10
2008 G8 GT
Rick Crawford Tuned
663/596 Rwhp rwtq for now....
10.87 at 133 1.59 60ft
Im in the same boat, I have a set of HSV summer wheels that will clear cts brembos but I want to use either my 18" or 19" oem wheels (oem wheels all fit just need spacers & longer studs) for all-season winter option. $110 for only ten??? , minus the shipping what makes these stud so pricey? I've looked at using 1" spacer/studs, but don't know if it will look odd with a wider stance.
http://www.ebay.com/itm/5x4-5-Wheel-...item3a6b91aec8
2009 Voodoo Metallic Blue G8 GT
1 of less than 1,111
Premium/non-Sport & no-roof >
HSV Engine Cover, HSV R8 8/9.5x19 Clubsport summer set, Corsa CB,
18" Drag-37 winter set, Pontiac cargo tray, Vararam OTR, V6 Radiator Cover,
BMR Sways, Yellow +09 CTS-V Brembos, LLumar Ceramic Tint 40/30/15%,
5 Year Plan: Kooks Mids, Pat G Tune, 3.27 Dif, HSV Front Guards & Flutes, E3 Front Bumper
I have the CTS-V Brembos front & rear with 8mm spacer(universal)on 19" wheels.I used the studs from a Silverado 2500 truck.Paid about 85.00 for 20.Fit is OEM.
Solo cat back exhaust, Rotofab intake, HSRK, VMS tune, Lovells Eliminator struts/shocks springs, Pedders sway bars, long gone Spohn front LCAs, GPS center stack trim
Rule #1 - Cardio
Zombies lead a very active lifestyle. So should you.
Are these studs something like these by Dorman at O'reilley's for $2 a piece. http://www.oreillyauto.com/site/c/de...eyword=610-428
Dorman
Thread size M14 x 1.5
Length total 65.40mm
Knurl diameter 15.70mm
Shoulder length 16.20mm
Auto Zone Dorman but its $5 each http://www.autozone.com/autozone/acc...ier=70714_0_0_
Length total 69.75mm
Knurl diameter 15.697mm
Should length 12.199mm
Oem
Length underhead to first usable thread 45mm
Length underhead to extremity 58mm
Shoulder length 13.40mm
Got this info from other site member Explicitsaint
I think ExplicitSaint said it took a lot of effort to get those Dorman studs in so I wonder if the published specs for the knurl size are correct for the Dorman pieces.
Rule #1 - Cardio
If the new studs are just a hair bigger you have to make sure the knurl knuckes that go into the hub are completly clean and lubed, another trick is to frezze the studs overnight so the metal could shrink just a bit to fit in. Also since it's such a tight fit behind the hub I'd use a C-clamp and a pipe after linning up the teeth press it in as far as can get it and then use several washers for friction resistance and tighten them down. The only problem that others have been having is removing the back studs. Shawn STL is having a difficult time getting them out.
