Results 1 to 10 of 18
Thread: Airbag sensor and module in the dash?
    Default Airbag sensor and module in the dash?
    My airbag fault light came on last week and the dealer has ordered two parts:
    92225595 Module
    92220398 Sensor
    Will either of these require taking the dash apart? If so, I need to probably undo some of my HSV gauge wiring so they don't screw it up when the take the dash panels off.
    Central Ohio
    I am sure that someone who can look up the PNs will be able to give you a better answer but these could be in the seat.
    Jan 2010
    I know theres one under the center console toward the back. Not sure if thats the whole module or just the roll/axis sensors.
    I called the service tech. He says both parts are in the passenger seat. One is the weight sensor and the other is the associated module.
    Jan 2009
    I've got an airbag fault. Got two codes B0081 and U0170. Any way to determine if I need the 'Module' or the 'Sensor' or both. At 300+ dollars each, I'd like to know I was ordering the right part the first time.
    Thanks
    I never got any codes from the dealer, so I don't know if you've got the same problem or not.
    92225595 Module
    92220398 Sensor
    Item 027
    Item 031
    http://parts.nalleygmc.com/showAssem...=0&modelYear=0
    Quote Originally Posted by edfiero View Post
    Thanks
    http://www.grrrr8.net/crazypaul/PIC4917.pdf
    http://www.grrrr8.net/crazypaul/B0081.pdf
    http://www.grrrr8.net/crazypaul/U0170.pdf
    Jan 2009
    Paul, thanks for the tech documents.
    Senior Member G8chick's Avatar
    Feb 2012
    Red Deer, AB
    I had this replaced in my car a few months ago. Light just came on and it was a whole module that needed replacing. At my expense.
    Good luck!
    2009 sport red v6
    -helo rims
    -k&n intake
    -solo axle back
    -Overkill tune
