FRONT SUSPENSION TIGHTENING TORQUES
REAR SUSPENSION TIGHTENING TORQUES
Wheels with other than +48mm offset = off design scrub radius.
Wheels with less than +48 offset move outward increasing the scrub radius.
VE Commodore Sedan SS V-Series Special Edition, Left Hand Drive, PBM, Hacked Atari Gauges
Power: 2014 Chevy Performance LS3 Crate Motor; Patrick G Tune, VCM Intake, Vector HSRK; Solo High Flow Cats, Solo Mid-Pipes
Appearance: Vortekz Generators; RedlineGoods Shifter Boot; Holden Badges; GXP Diffuser; Stub antenna
Handling: BMR Sub Frame Bushings, CTS-V Wheels, 255/40 & 285/35 Bridgestone S-04 Tires, GXP Rear Stabilizer Bar
Brakes Centric Premium Rotors, ACDelco Ceramic Pads
Wow, I'm guessing that non of the regular alignment shops replace all the bolts and nuts it says to replace in that list. Are all of those TTY?
Thanks Paul for the info. Understand that the parts are not reusable. I wonder if this is true for the aftermarket bolts as well. One of the reasons I am holding off on a new alignment until after Spohn releases the new LCAs.
Old Retiree in a Infiniti
Current Car - Infiniti M37S
Oye. I'm having major issues with my car shaking and wobbling. I've had the Pedders Street 2 with drop. I'm thinking that I need to get a wheel balance and alignment. The place where I purchased it aligned the car and gave me the specs. Looking at this instructional, I can't imagine that the jackass around the corner will do it right and the one that I bought the suspension from isn't interested in me anymore. What to do??
Ken
________________________
2009 Sport Red Metallic G8/GT Premium and Sport package - Sunroof
Mods-
Valentine V1
Magnaflow Cat back 16795
Roto Fab CAI and radiator cover
E&G screens front and back
Pedders Street II drop kit
Front and Back Sway bars
VIM with back up camera
DVD player
Carbon fiber interior kit
Holden steering wheel and matching shifter control
Holden Sunshade
I finally figured out the front caster adjustment requires part number 92218339, it is called an Adjuster Kit ...
09' GT PBM, Vararam, SLP Loudmouth, Tuned via HPTuners
To adjust caster, order a caster adjustment kit (p/n 92218339). The kit includes one replacement control arm retaining bolt, two offset washers, and one replacement prevailing torque locknut.
One kit will do one side of the vehicle. Follow SI document ID 2322935 for installation.
http://www.sandyblogs.com/techlink/2...ment-tips.html
Hi Paul,
Does this info cover the GTS with MRC? Also would you have details on a TSB for rear suspension knocking noise? I have read on LS1 that there is a TSB to cover this and that it says a washer needs to be replaced on the lower damper. Not being a technical guru would you be able to point me in the right direction?
Cheers
Auzgts
2007 VE HSV GTS
I'd think so.
The MRC is all about dampening and ride quality....that doesn't affect where the wheels point.
I've got the supplementary info for MRC cars and the only extra info in the Suspension Repair section is all about switches and sensors.
If you can come up with the TSB or Techline Document number I might be able to go and get a copy from a dealership. I don't have access otherwise.
You could try getting the Document ID number or a copy of the document from one of the guys on LS1.com.au who work at a dealership.
