Results 1 to 7 of 7
Thread: Harmonic Balancer Torque spec?
    Radical Advantage CanadianEh's Avatar
    Nov 2008
    New Brunswick, Canada
    Default Harmonic Balancer Torque spec?
    Hey guys, wondering what your torquing your balancers to?
    After my cam install I went over all the bolts and the balancer was loose again, I used a balancer installer and then torqued it to 150 lbs which is what alldata said. My friend asked someone he knows what he torques them to on vettes and he says 230 lbs. I presume 150 isnt enough if its backing off, so I take it 230 would be right?
    Also I really hate the design im tempted to slot the crank and balancer to put a keyway in it for ease of mind.
    2009 Hot White Pontiac G8 GT
    HP Tuners, Vararam, Vector Motorsports Stage 2.5 Cam, Kook's, Magnaflow, 3.45 Gears, Circle D 3200, FAST LSXr 102, Nick Williams 102mm, HP Tuners, Custom Transmission pan, Powdercoated Engine
    Sugar Land Texas
    If it is a ARP bolt, 230 ft lbs.
    Friendswood, TX
    Quote Originally Posted by CanadianEh View Post
    According to the Magnuson manual and other stuff I've read......they come from the factory tightened to 240 ft lbs with locktight!!!! Yikes! Try doing that on your back in a garage by yourself!!!!!
    Nov 2008
    thanks Charlie
    and yea that would be super rough on a garage floor on your back, luckily you can get to it from above
    Senior Member Identity Crisis's Avatar
    Edmonton, Alberta CAN
    Thanks Charlie you rock.
    2009 Pontiac G8 GT
    GXP Front Facia | GXP Rear Valance | K&N Intake | SLP/Powerbond UDP | MSD 8.8 Wires | E3 Spark Plugs | 180Deg Thermostat | HSRK | Apexi Grounding Kit | Goodyear Gator-back Belts | 6000K HID Headlights | Billet Oil Cap | Thirdshift Custom Cubby Plaque | GM Performance Division Plaque | Nylon Braid Wire Loom | Specter Hose Clamps | SS Alan Key Valve Cover Bolts | Redline Water Wetter | Amsoil Synthetic Power Steering Fluid | Mobil 1 0W40 Synthetic Oil | Amsoil EO 50 Oil Filter | Cleaning & Detailing by Meguires Products |
    Senior Member Brian@RPT's Avatar
    Jul 2010
    Austin, TX
    Spec is 240 ft-lbs with a GM bolt. Remove the bolt and replace with a new TTY Bolt. Torque to 37 ft-lbs and stretch 140 degrees.
    Quote Originally Posted by RPT View Post
    Most of us tossed the GM TTY bolt, went with the ARP.
