Brand: BMR Fabrication
Price: Group Buy for a great deal!
Purchased From: Kyle at BMR fabrication
Installation: Rear was very easy, took less than 15 min. Front took a little time and a lot of patience. Took as much time to get the OEM bar out as it did to get the beefy BMR bar in. We found holding our left foot up, waving our right fist around and cursing at it was the magic combo.
Installation Time: I think it took around 3 hours for both, taking our time and not rushing anything.
Any Installation Tips You Have: Have someone else do the front bar, anyone can do the rear.
Front Sway Bar Settings
Hole 1 - 87% stiffer than OE bar
Hole 2 - 137% stiffer than OE bar
Rear Sway Bar Settings
Hole 1 - 91% stiffer than OE bar
Hole 2 - 164% stiffer than OE bar
Hole 3 - 286% stiffer than OE bar
Quality of Part: (rate 1-10) 10. Very good welds and excellent fit/finish. The only thing I would change would be to add 90 degree fittings on the front bushing brackets to make greasing them easier. We tried to do this, but couldn't get the new ones to fit properly.
Product Performance: (rate 1-10) 10
Any Other Comments: Worth every penny! If you drive mostly on smooth pavement and want to stay very flat around corners, I'd suggest these bars on the stiffest settings. If you live where the road is broken or rough, you may want to start with the softer setting.
