Results 1 to 10 of 14
Thread: Best GPS for Trim Package Mod
    Member JayCo59's Avatar
    Jan 2010
    Windsor, Ct
    Default Best GPS for Trim Package Mod
    There were some discussions on this in the original Thread, but I wanted to have a more detailed discussion on this topic as there may be features on some GPS's that I'm not aware of.
    I understand there are physical issue that requires a specific size and external connectors could interfere with the mounting straps and you need to be able to control all aspects of the device by the screen. But beyond that we have so many potential units to choose from.
    My research has gotten me to the Garmin Nuvi 265WT or possible the 285WT.
    But maybe others have had luck with other manufacturers or other models.
    Thx,
    Jay
    ___
    Metalic Gray '09 V-6 Sun and Sound.
    Love the Low-End Torque!
    VIP Member 08G8V8's Avatar
    Savannah, GA
    I've got the Garmin 765T. I had a Garmin 760 but it crapped out on me. I wanted a unit that has bluetooth for handsfree calling.
    Feb 2009
    A Hotel
    I have the 755T... didn't want the Bluetooth from the higher models, but wanted the ability to program in custom routes and FM traffic updating. It required modification of the JHP bracket, but I don't think modification would be needed with CP's. Some of the newer Garmin models (1xxx stuff) would probably work as well, but I don't know for sure.
    What I really want to see is the EcoRoute ESP (ODBII integration) that was talked about at SEMA.
    -Todd...
    Jan 2010
    Windsor, Ct
    Quote Originally Posted by TCorzett View Post
    -Todd...
    Todd,
    That ESP unit looks way cool! Maybe I'll wait for that?
    Jay
    ___
    Addicted Member silver6.0L's Avatar
    Nov 2008
    Northwest, Indiana
    I've also got the Garmin 765T and it works great.
    2009 Maverick Silver G8 GT
    Central Tx/ Albany Ny
    i have a garmin nuvi 205 its real thin that i think will work, i thinks its the series that is meant to fit the one jhp sells.
    Jan 2010
    Windsor, Ct
    Default Another OBD\GPS device.
    I found another GPS system that integrates OBDII called DashDAQ and it's available now, but pricey.
    Check it out.
    url removed, see update below.
    Jay
    Additional Info:
    DashDAQ Series II Technical Specs
    Display - 4.3” COLOR TFT w/touch panel
    Resolution - 480 x 272 (QWVGA) w 24-bit color display
    System Processor - 240MHZ ARM9
    Vehicle Bus Processor - 48MHZ ARM7
    RAM - 64MB SDRAM
    Flash - 32MB Flash
    Memory Expansion - MMC/SD Card 128MB to 32GB+
    Device I/O
    - touch-panel, ambient light sensor, 16-bit stereo line-out, 1W speaker, USB device port, programmable button
    Vehicle I/O
    - CAN, J1850VPW (GM Class 2), J1850PWM (Ford SCP), ISO9141, KWP2000
    Expansion I/O
    - (2) USB Host Ports, (2) RS232 Ports, (2) 0-5V 10-bit analog inputs
    Add-on sensors
    - Blackline GPS (up to 20HZ), Innovate MTS Bus products, 0-5V Wideband O2 Sensors, NMEA GPS, USB 3-axis Accelerometer, USB K-Type Thermocouple
    Parameters Available
    Over 2000. See Vehicle list HERE and accessory list HERE
    Operating temperature
    -35 to 85C
    Operating voltage - 6 to 30V
    Current Draw - 200mA at 100% backlight
    Low Power Mode - YES
    Dimensions - 5” x 3” x 1”
    Weight - 0.5LB
    Operating System - Linux
    Warranty - factory tested with 1 year warranty
    Other Features
    - Real Time Clock, locking connectors, factory tested, field upgradeable firmware
    Mounting Pattern
    - AMPS 4-HOLE standard
    Package Contents
    - DashDAQ, Vehicle Cable, USB Cable, Windshield Pedestal, CD-ROM, users manual
    2/16/2010 - UPDATE...
    Don't bother with this product, The company is owned by one Guy and he's a real loser (I want to say worse but I'm trying to keep it civil). I asked him for some info on the unit and he came back with a very short and minimal answer. When I complained that I would have hoped that he would have been more responsive he refered to me as an A--hole and told me to go bother someone else. So much for customer support!
    ___
    Beyond Help gearhead455's Avatar
    Feb 2009
    Tonawanda N.Y.
    I got the Delphi NAV300 it has blue tooth calling too,I used low tech velcro in front of the cubby and the cord stows behind when not in use,I will get the cord hardwired eventually.
    Panther Black Metallic
    Premium and Sport packages
    NewEra dyno tune,NewEra ported TB,Yella Terra intake tube,K&N air filter,Spintech stainless axleback mufflers,caliper covers,GXP Diffuser,chrome lug caps,Pontiac trunk mat,Holden V-8 badges.
    <a href=http://i67.photobucket.com/albums/h309/bluesman455/Car%20Pics%202010/DSC03883-2.jpg target=_blank>http://i67.photobucket.com/albums/h3...DSC03883-2.jpg</a>
    Jan 2010
    Windsor, Ct
    Default I like it!
    Quote Originally Posted by gearhead455 View Post
    I like your low-tech velcro solution, I was thinking of "rigging" a metal bracket that would secure the GPS to the back of the cubby and run the power through a hole I'll drill in the rear of the cubby. I realize this solution is not as "professional" looking as the in-dash mod but it will be a whole lot cheaper! And you have access to all the side and rear USB/SD connetors and allows for just about any GPS\Diag device to go in that area.
    Jay
    ___
    Central Ohio
    Quote Originally Posted by JayCo59 View Post
    Jay
    If you do that you will not need to drill a hole. The top of the cubby is open so you can run the power cord out of there and into the area behind the radio.
    Also I had my GPS "rigged" up that way before getting the trim from Paul and it worked ok but was a real pain to keep an eye on it while driving.
