Results 1 to 10 of 16
Thread: Service Engine Oil?
    Default Service Engine Oil?
    Guys, drove my wife's GT tonight and noticed that the service engine oil notice came when I shut the car off. I changed the oil (TropArtic 5W-30) about 2000 miles ago, 2-3 months ago. The factory fill went over 6000 miles.
    Highs have been consistently above 90* and we have had a lot of 100+* days around here this summer. She does a lot of city driving, but 2000 miles? Can this be right?
    VIP Member zepcom's Avatar
    in the g8
    Quote Originally Posted by RevGTO View Post
    I suspect that you never performed the "Engine Oil Life reset procedure" as outlined in your car's manual. It's something along the lines of key on "run position" but car still turned off, and press the accellerator petal 3 times within 5 seconds, and it's reset. Then turn key-off.
    Each time you change the oil, use the procedure to reset the engine oil life monitor system. Since you didn't reset it, it probably calculated your origonal factory fill (6k) plus the latest oil change of 2k, and thought that after 8k total (counter never reset) that now it's time to change your oil.
    If you go into engineering mode on the car (hold down the left scroll wheel when starting the car, then use same scroll wheel to flip through all the choices presented) you will see a topic called "Engine Oil Life" ... betcha yours is near zero. After you perform this reset procedure as above, it will reset to 99% or 100% and then you have 6k-8k more miles before the next change (some have differing viewpoints on this, do what feels comfortable with you!)
    Hope this helps...
    --zepcom
    Good times.
    Banned
    Jan 2009
    Chicagoland
    Reset the OLM like Zepcom said, then change the oil after 5000 miles and you should be ok.
    I did the reset when I changed the oil. I changed the oil in the first place because the service engine oil light came on. Had I not reset it, it would have stayed on. I have driven the car from time to time, and it has been off. It just came on the other day. BTW, the oil level is full and it looks quite clean.
    Bothell, WA
    Do you get your OnStar reports? What does that show for oil life?
    Did you confirm the reset took in engineering mode? Are you 100% sure you reset? I wish the oil life was in the DIC like in my Grand Prix. You could pull it up with the three or five button trip computer, and the reset procedure was much easier. Is it possible the change oil light would come on after 2K to 3K miles? Well, I guess if that was 2K to 3K miles at Talladega I guess it is possible.
    2009.1 Pontiac G8 GT
    Banned
    Jan 2009
    Chicagoland
    It sounds like the OLM is messed up and I believe that info is stored in the BCM. You should take it to the dealer and have them check it out. In the mean time change the oil after 5000 miles and it'll be ok.
    Checked with the wife and she let Onstar run out. I didn't check engineering mode because I didn't know about it till this thread. Knowing from LS1 experience that there had to be a reset procedure, I just opened the owner's manual, found it, and did what it said: turned the key to "on", pumped the throttle three times within five seconds, turned the key off. The service message didn't come on again, and I figured all was good ... till now.
    Quote Originally Posted by DRCUSTOMPARTS View Post
    Yep, probably should do that. I've been thinking to do that anyway, because the cats have stunk since new, and it hasn't gotten any better as time has gone on.
    VIP Member MongosG8's Avatar
    Connecticut
    I would go with what the Doc ordered ..LOL!
    I had brought mine in for the same thing. I had reset the OLM twice and it came up again for the third time.
    OnStar showed my old life going from 99% to under 10 percent in a very short period of time so I knew something was up.
    The dealer ended up updating or doing something to the ECM and all was fixed.
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
    Oct 2010
    Not to jack his thread but I switched to Royal purple and a K&N gold filter and so im good for like 7000 miles before i need an oil change and its only been 5000, so my service engine oil light has been on for a few weeks and now my check engine light is on. Will reseting the oil life counter clear the check engine light as well?
