Results 1 to 10 of 14
Thread: DIY: Installing a Wideband O2 Sensor and Module
    Senior Member Jaysin's Avatar
    Jan 2009
    St. Louis, MO
    Default DIY: Installing a Wideband O2 Sensor and Module
    Here is a DIY tutorial I put together on this. Hope it helps someone with their project if they decide to do it.
    http://www.g8modz.com/wideband.htm
    STL
    good stuff jason..
    im getting my Wideband next week but will be using mine from car to car to tune..
    where did you find the pinouts for the cable? i got the hptuners pro just gotta hook it up
    Jan 2009
    St. Louis, MO
    They were in the instructions with the PLX wideband I got.
    STL
    good deal ive been borrowing my buddys LM1 and it has a seprate box i have to watch
    Jan 2009
    St. Louis, MO
    Quote Originally Posted by shane View Post
    The LM1 should have an analog output. If you go to:
    www.hptuners.com/help --> Working with VCM Scanner --> Enhanced IO --> Connecting
    You'll see how to connect the analog output. Then go to:
    www.hptuners.com/help --> Working with VCM Scanner --> Enhanced IO --> configuration
    There it explains how to setup the LM1.
    Hope that helps.
    Very clean neat install
    2000 SS Camaro black 395 stroker, custom Pitbull cam, hand ported LQ9 heads, 2 small stages of nitrous, TH400, 9' rear 3:70 gears, pump gas daily driven 9.42 @ 142 car is apart for it's next setup 25.2 cage and lots of boost
    YOU CAN'T RUN WITH THE BIG DOGS IF YOU PEE LIKE A PUPPY!
    In the middle of NC
    Very clean install and very helpful. I'll be doing this in the next few days. Thanks for the write up. I've stickied this.
    - John Henry Boetcker
    Jan 2009
    St. Louis, MO
    Thanks all and thanks for the sticky!
    VIP Member PerfectD3's Avatar
    Valdosta, GA & Deland, Fl
    Whenever I get my new camera I'll take pics of mine, used the same grommet but routed everything to the glovebox. Seeing the AFX at night is too bright and it's easy to close the glovebox. For anyone else thinking of doing this, if you tap the fuse box for power think about grabbing a relay and putting one in to shut off the O2 when you aren't driving.
    Very stock... looking.
    3E5X1 US Air Force
    Deployed...errr...Vacationing at Eskan Village, KSA
    Lucky SOB G8GT721's Avatar
    MA
    Quote Originally Posted by PerfectD3 View Post
    i think i remember reading that the O2 can be damaged if not power up while the engine is running
    It is very important that the Wide Band Commander
    Sensor is powered up when the vehicle is running.
    The sensor may become damaged if the vehicle is
    running and the WBC is not receiving power. In the
    event that you don't have power running to the sensor,
    remove it and install the weld boss plug included
    in the WBC kit.
    this kits uses a Bosch sensor
    2008 White Hot G8 GT
    SLOWHAWK Tuned
    My Garage
