03-28-2017, 09:22 AM
#11861
Moderator
Took it for an alignment after doing a complete suspension overhaul.
Len
03-28-2017, 09:25 AM
#11862
LDM
I need to get that done to the Rat, what kind of goodies did you install and how much did it hit ya for?
2009 Panther Black Metallic "
The Black Rat"
Sounds so
GRRRR8 BECAUSE RACE CAR
Curt here
03-28-2017, 09:27 AM
#11863
The Black Rat"
Sounds so
Curt here
03-28-2017, 09:50 AM
#11864
Moderator
texn884
These were all parts that I bought years ago and had been putting off installing so I'm not sure the total price off the top of my head. I had a lower control arm ball joint start clunking so i finally had to do something. In the front I put new LCAs and radius rods with BMR bushings and Whiteline caster lock washers, FE3 struts with Whiteline strut mount bushing/bearings, BMR swaybars and endlinks. In the rear I installed FE3 shocks, BMR swaybar and endlinks, BMR trailing arms, BMR adjustable LCAs, BMR LCA knuckle bushings, BMR adjustable toe rods, and BMR subframe bushing inserts. It turned into a bigger pain than I was hoping for, but it's done now and the car seems to drive alright.
Len
03-28-2017, 10:09 AM
#11865
The Black Rat"
Sounds so
Curt here
03-29-2017, 02:38 AM
#11866
Moderator, Retired
STL_G8GT
What the ffffffffffffffffff?
I'm not calling you this time!!!!
Wasn't a big deal. Front caliper bolt backed out.
RichsGreyGT
03-29-2017, 03:24 AM
#11867
Had a new set of General GMax AS-03 installed, hopefully they will hold up longer then the Sumitomos that they replaced!
--Brian--
2009 Pontiac G8 GT
2008 Chevy Impala SS--Traded 4/1/2021
2016 Dodge Challenger R/T Plus
2001 GMC Sierra
GODSPEED CHARLIE!!! R.I.P.
03-29-2017, 05:53 AM
#11868
-Ray-
Look at you with the good luck!
03-30-2017, 04:11 PM
#11869
Drove the car for almost 45 min!
In the process of getting data for Pat G. Discovered the car will break the tires loose when boost hits in second gear 😱
Sent from my Pixel XL using Tapatalk
03-31-2017, 02:53 AM
#11870
Moderator, Retired
Opened up all the windows so the smoke smell would go away.
RichsGreyGT
