12-31-2015, 02:43 PM
#10881
Swapped my NGK WB for a AEM xseries. The NGK was consuming most of the glovebox. The AEM is a 4.9 head, has rs232 out that should eliminate any ground concerns with the WB into HPT. Made my own mount out of ABS and harddrive magnet.
Sport /Premium
12-31-2015, 04:25 PM
#10882
Got my full size spare powdercoated gloss black to match the set on the car.
12-31-2015, 06:38 PM
#10883
Drove it for the last time.
This year.
01-01-2016, 03:34 AM
#10884
Moderator, Retired
RichsGreyGT
01-03-2016, 06:26 PM
#10885
-Ray-
Ordered a drivers door.
What happened to the other one on the car Ray?
2009 Panther Black Metallic "
The Black Rat"
Sounds so
GRRRR8 BECAUSE RACE CAR
Curt here
01-03-2016, 06:59 PM
#10886
Now it's a Party
Uncovered it and installed new rotors and pads on all four corners.
R.I.P. Charlie
01-07-2016, 07:18 PM
#10887
Coincidence?
Two track visits ago I was done in by what turned out to be my differential. I sent it back to Wavetrac with the axle stub still stuck in it since no one could get it out. They could not get it out either. They did find a clearance issue that they are going to correct and repaired it under warranty.
Last visit I was done in by what turned out to be a canbus oil pressure gauge. Speedhut replaced the circuit board in it under warranty.
Last week I got shipment notices for both parts back to me within an hour of each other. Today they arrived within an hour of each other. Maybe this is the sign that the dark cloud following me will find someone else to bother. At least I am having issues with parts that I have a warranty on now.
01-07-2016, 07:53 PM
#10888
I picked up my G8 from Rick Crawford!
I had him install the Little Lunati cam, DOD delete, and he ported/milled/flowed my 5364 heads.
It is an absolute monster! However it idles like a champ, is completely daily driver friendly with my stock converter, and averaged 20mpg on the way home on Interstate 95 running 77mph.
I am impressed!
Thanks Rick!
2008 G8 GT - Liquid Red - Sport Premium
Rick Crawford Built! 11.0's @ 122mph.
Dominator Cam, H-E Series Head Port/Mill/Flowed, throttle body, intake & tune, headers, 3.45 gears, Circle D, E85.
Instagram - TTSaleen
Youtube -
www.youtube.com/98saleen
01-08-2016, 08:04 PM
#10889
Sport /Premium
Post Thanks / Like - 0 Thanks, 4 Likes, 0 Dislikes
01-09-2016, 05:17 PM
#10890
Put my GT in storage filled up air in my tires, put in gas stabilizer, had it under sprayed, took out the battery & finally put a cover on it.
