so what I've come up with is this...your ecm will initially see the car running lean using a fuel with a higher alcohol content...this will cause the car to add fuel....so when I saw my LTFT go a lot more negative, I was apparently running fuel with less alcohol content.
pretty good info in this thread..
http://forums.evolutionm.net/engine-...5-ethanol.html
so I think after reading this, the point is to stick with a fuel, and have your car tuned using that fuel. Correct me if I'm wrong Charlie.
