Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Hard to find Pontiac Parts
    Default Hard to find Pontiac Parts
    Seems like every day now I'm being asked if I can supply something that GM NA can't.
    Here's some examples of parts I can usually have on a plane the same day for you.
    Prices include Shipping.
    Pontiac G8 Upper Kidney Grilles
    92201780 left & 92201781 right.
    (Plenty of stock available now, 10 April 2010).
    US$115 each shipped by Airfreight ETA 14 days.
    US$215 both shipped together by Airfreight ETA 14 days.
    Pontiac G8 Hood Vents (unpainted).
    92221708 left & 92221709 right.
    2 x left (USA drivers side) & 4 x right (USA passenger side) Available.
    US$200 each shipped by Airfreight ETA 10 days.
    US$390 both shipped together by Airfreight ETA 10 days.
    Pontiac G8 Front Arrowhead Emblem Red 92205700
    US$50 shipped by Airfreight ETA 14 days.
    Pontiac G8 Trunk Arrowhead Emblem Red 92205490
    US$40 shipped by Airfreight ETA 14 days.
    Pontiac GXP lower rad grill 92213351
    US$110 shipped by Airfreight ETA 14 days.
    Pontiac GXP Front Bumper Rubber Lower Insert 92224778
    US$75 shipped by Airfreight ETA 14 days. EDIT --- STOCK IS AVAIL AGAIN Mar 19th 2011.
    Pontiac GXP Front Foglight Bezel 92213349
    Pontiac GXP Front Foglight Bezel 92213350
    Pair of Pontiac GXP Front Foglight Bezels 92213349 + 92213350
    US$70 shipped by Airfreight ETA 14 days.
    Pontiac G8 Rubber joins Airbox to MAF 92068223
    Pontiac G8 Clamp for Rubber Airbox to MAF 92068284
    US$20 shipped by Airfreight ETA 14 days.
    Pontiac Rubber 92068223 & Clamp 92068284 shipped together.
    Pontiac G8 Pollen Filter aka Cabin Air Filter 92184248
    US$42 shipped by Airfreight ETA 14 days.
    US$76 shipped for 2 together, by Airfreight ETA 14 days.
    Pontiac GTO 2006 Black Tail Lights.
    1 x 92149071
    1 x 92149072
    I can do a set shipped by Airfreight ETA 14 days for US$400
    Pontiac G8 Rocker Panel Moulding Retaining Clips.
    92138808
    92138811
    92138807
    Pontiac G8 Gutter Trim Molding replacement clips
    92207444 forward of the green clip, 7 reqd per long curved trim.
    92207443 the green clip, 1 reqd per long curved trim.
    92207442 rearward of the green clip, 2 reqd per long curved trim.
    Pontiac GXP Brembo Caliper Securing Bolt M12x1.75 UHL44mm 92139080
    Pontiac G8 Knuckle to Caliper Bolt (same front and rear, 8 per car) 92172963
    Pontiac G8 Brake Banjo Bolt 92193458
    Pontiac G8 Wheel Stud 92171058
    Pontiac G8-GT V8 Top Radiator Hose 92157816
    US$38 shipped by Airfreight ETA 14 days.
    Pontiac G8 Jack Tool Kit Parts
    Top Bolt goes thru spare 92199316
    Top Knurl Nut goes above flat retaining plate for tools 92188779
    Retaining plate for tools 92183592
    Screw Scissor Jack 92208027
    Jack handle 92187172
    Plastic cap remover tool for lug nut plastic caps 92171594
    Plastic donut for tools 92213090
    Lug Nut Wrench 92194803
    Large plastic screw fits Top Knurl Nut 92158662
    Pontiac G8 Round Front Tweeter Cover Black 92190146
    Pontiac G8 Front Central Speaker/Ventilation Cover Black 92218486
    Pontiac G8 Small Square Plug inside front internal door handle
    Left side 92180174
    Right side 92180173
    Pontiac G8 Stereo Faceplate Clip 92206356
    Pontiac G8 White Clips for console/dash/gear surround 92139070
    Pontiac G8 Main Instrument Cluster Lens - Clear 92196354
    Pontiac G8 Atari Harness US$30ea shipped.
    HARNESS ASM-I/P WRG HARN EXTN
    Pontiac G8 Single Button Traction Control switch with bezel Rado silver 92189948
    Pontiac G8 Small parts kit for Clear Headlight Protectors (spare clips etc) 92203858
    Pontiac G8 Cap for rear of headlight assembly 92193038
    Pontiac G8 Push in Rivet for Radiator Cover 92138218
    Pontiac G8 and GTO Rubber Bush for locating 2 piece engine covers 24453627
    Pontiac G8 Front suspension, Rear lower control arm including ball joint and bush.
    (See Parts Drawing in Post #14 of this thread.)
    #5 - 92183309 - R - passenger side. Updated Part Number 92244050.
    #5 - 92183310 - L - drivers side. Updated Part Number 92244051.
    #7 - 92224668 - R - passenger side. Updated Part Number 92244046.
    #7 - 92224667 - L - drivers side. Updated Part Number 92244047.
    New 2010 LCA's in stock now.
    Edit---- See this thread for Lower Control Arms
    http://forum.grrrr8.net/showthread.php?t=17477
    TAILSHAFT PARTS.
    92138569 Gearbox flange to rubber coupling bolt (3 required)
    11094255 Gearbox flange to rubber coupling nut (3 required)
    92149040 Coupling Kit (includes coupling + 3 nuts and 3 bolts) Can be used at gearbox or diff end.
    11561372 Bolt, bearing support (2 required)
    92139104 Diff flange to rubber coupling bolt (3 required). No nuts required.
    The Items shown above as NO LONGER AVAILABLE were recently tagged as "Not for Domestic Sale" by Holden, meaning I cannot buy them in Australia anymore.
    30th Oct 2009.
    Last edited by Crazy Paul; 06-25-2014 at 10:55 PM. Reason: Most GXP items available again
    VIP Member beach's Avatar
    Jan 2009
    Great list and prices from Oz, Paul, and thanks again for getting me that last GXP fascia piece I needed and couldn't seem to get anywhere here
    2009 G8 GT - Sold...
    Pacific Slate/Onyx, Premium/Sport - 3M Clear Bra, 20% Rear Tint, GM Trunk Mat, Dimming Mirror, Holden VE Rubber Floor Mats, VMS TCM & 93 ECM Tune, Roto-Fab CAI & Radiator Cover, Pedders Bushings, Holden 6.0L Badges, GrafxWerks Badge Overlays, GXP Front Fascia & Rear Diffuser, JHP GPS Kit & Garmin, BP Catch Can, FE3/GXP Dampers, Corsa Cat-Back, GY Eagle GT Tires, GM Accessory Shift Knob
    MPGTune.com Mileage History
    Question AH?
    What is this?? Pontiac G8 Pollen Filter 92184248
    Is that the same as the air filter??
    Twin Turbo 2000 SS Camaro(486RWHP,493 RWTQ) SOLD
    2009 Pacific Slate G8 GT
    2006 Daytona Sunset Orange C6
    2005 Sunbusrt Orange Colorado Z71
    Central Ohio
    Quote Originally Posted by fredl11 View Post
    No, its your cabin air filter.
    Quote Originally Posted by BlueJacket View Post
    Employee of the Month.
    VIP Member G8GT594's Avatar
    Northville, MI
    What would we do without CP?????
    Can't move out its own way- idk what number motor its on, how much boost, how big of a shot, its starts, im happy.
    SoCAL
    Good job C.P.!! this is an awesome list!!!
    I agree with everything you said in your PM earlier.
    LISTEN UP GM!!! Pay your bills to get paid!!! RIGHT?
    **RIP Shaun Finley**
    FUCK CANCER
    **RIP Charlie**
    '16 2SS NFG Camaro M6 NPP Mag
    Central Ohio
    Shhhhhhh JHP all ready thinks I work for you,
    Beyond Help It's A G8!'s Avatar
    Next to you!
    Does this cabin filter have to be changed?
    Quote Originally Posted by It's A G8! View Post
    Yes.
    11-8 Service and Maintenance
    (l) If you drive regularly under dusty
    conditions, the filter may require
    replacement more often.
