Results 11 to 20 of 43
Thread: Hard to find Pontiac Parts
    Central Ohio
    Quote Originally Posted by It's A G8! View Post
    Does this cabin filter have to be changed?
    Have to be? No. Should be at some point? Yes, if you like clean good smelling air in your cabin.
    Edmonton, AB, Canada
    How much for all this?
    Pontiac G8 Jack Tool Kit Parts
    Top Bolt goes thru spare 92199316
    Top Knurl Nut goes above flat retaining plate for tools 92188779
    Retaining plate for tools 92183592
    Screw Scissor Jack 92208027
    Jack handle 92187172
    Plastic cap remover tool for lug nut plastic caps 92171594
    Plastic donut for tools 92213090
    Lug Nut Wrench 92194803
    Large plastic screw fits Top Knurl Nut 92158662
    Quote Originally Posted by ClassicPhysique View Post
    Greg @ Pace would be your best bet if you want the full kit.
    http://www.forum.grrrr8.net/showthread.php?t=1016
    Pontiac G8 Front suspension, Rear lower control arm including ball joint and bush.
    (See Parts Drawing below.)
    Original 2008 & 2009 Part Numbers.
    New 2010 Part Numbers.
    Yes they Retro-fit.
    GM uses these new lower control arms to repair 2008 & 2009 cars.
    Is there a GM part# for the black side molding window trim?
    Quote Originally Posted by twenty2indubz View Post
    6 part numbers.
    Not likely there'd be any in GM N/A stock since they're not fitted to Pontiacs.
    I do have some black trim kits going on sale shortly. What's your location ?
    6 part numbers.
    Houston, Texas.
    From the pic below, these are the GXP front parts I can & can't currently supply.
    A: YES. Pontiac GXP Front Bumper Lower Rubber Insert 92224778
    B: YES. Pontiac GXP lower rad grill 92213351
    C: YES. Pair of Pontiac GXP Front Foglight Bezels 92213349 + 92213350
    D: YES. Pontiac G8 Front Arrowhead Emblem Red 92205700
  9. #19
    do you have the part number for the radiator cover for the v8 motor?
  10. #20
    Senior Member ETIDMotorsports's Avatar
    Tempe, AZ
    Pontiac G8 Main Instrument Cluster Lens - Clear 92196354
    Is this the clear plastic lens that covers the gauge cluster? If so I was told at the dealership that this came as part of the gauge cluster assembly and could not be ordered individually. If it is how much would it be shipped to Tempe, AZ 85281. Also how hard would it be to install? Thanks in advance.
    2008 G8 GT - Ignition Orange Metallic
    SHOW - GXP Wheels and Rear Diffuser, Completely Debadged, GM Roof Rack, Thule Bike Carrier.
    GO - TVS1900, ARH 1 - 7/8" Headers, VMS Tune, BMR Trailing Arms, BMR Subframe Connectors, Pedders Sway Bars,
    My Tri Traveler
