Results 1 to 7 of 7
Thread: This stick looks alright.
    Default This stick looks alright.
    223/231 .610 .617 113 +4
    Untouched L92 heads.
    6.0 block.
    Clarks Summit, Pa.
    I read that thread too...
    Plastic Cuttin' Bad Ass!
    G8erator '02 ws6's Avatar
    White Deer, TX
    I've met the guy here @ our local races that owns the car. Definitely a stout combo! That's a Pat G cam, whom is the same guy that spec'd my new cam for the new motor going into my TA, but mine's a bit bigger. If I could ever convince the wifey, a custom Pat G would surely be going in the G8.
    Senior Member Horn09's Avatar
    Pearland, Tx
    any idea what kind of lobes it was ground on?
    Clarks Summit, Pa.
    Quote Originally Posted by '02 ws6 View Post
    I've been PMing with Pat a bit over there.
    I think I need to fill out one of his spec sheets.
    White Deer, TX
    I definitely would recommend that. He'll most likely call you shortly after and discuss your plans for the car, useage, and what type of performance you're looking for. Very in depth, and knowledgeable dude.
    Quote Originally Posted by Horn09 View Post
    That's usually up to you, mine was ground using LSL lobes. He normally uses Geoff @ Engine Power Systems for the ordering, and he has a proprietary lobe that has been throwing out some amazing power. It would probably be safe to say he would recommend you go with either, but he may recommend LSK or XER lobes (although he doesn't prefer them, and titles them as "outdated"), it depends on the setup and how you want it to perform mainly.
    From the Comp Cams LSr line of cams
    Comp LSL lobes.
    I: 13016R 273 223 147 .359” .610”
    E: 13018R 281 231 154 .363” .617”
