I'm getting a sucking sound after I installed my catch can. It seems to be coming from the can itself, has anyone else experienced this?
6.0L
Roto-Fab Intake
OBX 1 7/8 LT Headers
OBX Stainless Steel Exhaust
Custom Dyno Tune by Premier Autosports, Memphis TN
Nitto 555R's on 17" GTO Wheels (Drag Pack)
This is somewhat normal. As long as you have no check engine light you are OK.
Thanks Charlie!
6.0L
Roto-Fab Intake
best car i ever had. sold the car to buy a garage.
new daily driver? silver nissan sentra. new headliner mod, custom dent in the fender... but hey, it's been getting 35 m.p.g. since '97.
...and i don't need to worry about many of these anymore
follow me @ http://twitter.com/#!/kickitsimple
Yes she was actually. Maybe that's what I was hearing. Shouldn't I have felt it too?
On a more serious note, I checked the can after about an hour of driving and there was a small amount of oil inside. Working already! I've got 1,555 miles on the car, by the way.
I made the can from various parts from Home Depot, total cost was $32.00. I can post pics if anyone is interested, it seems to be working just as well as the expensive ones.
6.0L
Roto-Fab Intake
I see the penguin has been poppin viagra like tic tacs again
[QUOTE=StandFast85;112228]Yes she was actually. Maybe that's what I was hearing. Shouldn't I have felt it too?
I've got one as well. If it's one of those air filter bowl things for air tools. You might want to check out the little valve that drains it. On mine..if it pushes in to drain...that means that air pressure keeps it closed. YOu have to push in to drain it. But in this case..being on a vacuum,it will pull the valve open and always be pulling in outside air..aka a leak. Mine did that..made a small sucking sound. So I made a small spacer out of a rubber washer and slipped it over the nipple,which keeps it pulled out(closed). I just have to remove the spacer and push it in to drain it.
^maybe that helps....
gone but not forgotten
1.698 60' 11.946@113.66 BEST 60'....1.650
ENGINE....ls3 block,mahle pistons,forged rods,cloyes timing chain/tensioner,stock crank,clevite bearings,arp bolts through out.
VALVETRAINl92 heads(821casting) with lightweight exhaust valves/stainless intake valves,patriot gold dual springs/titanium locks/retainers,230/240 .595/.605 cam
EXHAUSTkooks mid length headers,no cats,magnaflow mip-pipe/resonators,no rear mufflers.
MISC..3.27 gears,spohn trailing arms,VMR V710'S....245/45-18 FRONT,275/40-18 REAR. CIRCLE D 3K
for now....'95 mystic teal ta,slightly built lt1,cam,headers,intake, tb,every suspension mod,c5 brakes,lowered,3.90 gears,corbeau seats,6-point cage,ZR1 rims.
^ that's interesting because mine is the air filter bowl filter thing. I used a rubber nipple to cover the spigot on the bottom of the bowl. It seems to be air tight now. I'm going to go out and check it again.
Thanks for the info!
6.0L
Roto-Fab Intake
