Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 84
Thread: $20 Oil catch can
  1. #71
    Addicted Member THE Adam V's Avatar
    Jan 2013
    North Canton, Ohio
    Quote Originally Posted by BigRed585Lbs View Post
    Where did you get the rubber lines? Probably a stupid question but I want to do this soon. I noticed a TON of oil when I put my ported intake on.
    2009.1 PSM GT Sport/Premium Package.
    OBX 1 7/8", 3" to 2.5" X-Pipe, SLP Loudmouth, 6k HIDS, VCM OTR
    Rick C Intake and Throttle Body, MM Carbon Fiber Hood, 19x9.5 TSW Nurburgring, Pat G Tuned
  2. #72
    By Marion, Mississippi
    Any auto parts store (AZ, Advance, PepBoys, KSK, etc.) should have it in bulk and cut it to whatever length you need.
    Just Sitting The Bench Now
  3. #73
    Jan 2013
    North Canton, Ohio
    That's what I figured. But I wanted to make sure before I waste the trip. Might as well get it all at once right?
  4. #74
    Dec 2013
    Zanesville, OH
    I just use fuel line Adam. Your autoparts store may actually have some PCV hose. My can works much better since modding it.
  5. #75
    I stuck one on the Camaro, too. Works the same.
  6. #76
    Junior Member MagneticSmoke's Avatar
    Sep 2011
    Question about these air compressor separators/filters:
    Could the guts be removed, then the flow reversed so the air enters the separator from the center? If so, you can attach something to help the air 'collide' and assist the oil coalesce.
    Something similar to what this guy did on his Dodge Ram.
  7. #77
    I'm old. I like old stuff. Old threads.
    Dual cans in series to catch all the oilsnot. Still less than $80.00 invested in the whole set-up.
    Latest mod to the red can:
    But then, nobody comes to this forum anymore.
  8. #78
    Dec 2015
    Some do. I like that set up.
    '09 WH G8 GT
    Premium/Sport
    Red/Onyx
    Rotofab CAI
    Cortex 93 tune
    20% tint
    I just wanted one.
  9. #79
    I actually just did a cheap catch can based off this. I used the Home depot husky version though which I do not recommend. The valve on the bottom needed to be sealed up a lot. Next one I do will be the Kobalt most likely.
  10. #80
    N.O.LA
    BigRed,
    How much collects in your second can?
    JAM - still here too
