Results 1 to 3 of 3
Thread: Swap a 4l80e and the 6l80e out
    Junior Member VE SS's Avatar
    Feb 2022
    East Coast Australia
    Default Swap a 4l80e and the 6l80e out
    Hi, This is my first post as I have just after buying a 2007 Holden VE SS Ute (Elcamino type body). I want to install a 4L80E in and take the 6L80E out. Pontiac G8's are a Holden Commodore in Australia (Majority of you probably already know this). I ran it last weekend (1/4 mile) and it ran a 12.64 @ 114mph - I am reasonably happy with it (I ran it as I bought it - just got it dyno tuned).
    I am definitely going to step it up and aiming to have final crank horsepower figure around 900HP.
    After talking to some people at the track, I hear that the 6L80E is one of the weak links and it was suggested that I install a 4L80E.
    Feedback from anyone who has done this to their G8 with an LS2/L98 motor would be preferable.
    What failed in the driveline?
    What other driveline modifications did you make?
    Thanks in advance.
    VIP Member Kermit's Avatar
    Va. Beach, VA
    Congratulations on your Ute.
    I have done NOTHING to my transmission (not even change the torque converter, which I probably should) and I did great times at the track. I haven't been active at the track for years now so I haven't been up on all the racing stuff but I don't think your transmission is the weak spot. Sure, going with less gears would help some but before you do that, why don't you change the differential? I put a Camaro 3.27 in that helped. Beef up the motor also will make better times.
    2009 G8 GT MGM.
    Feb 2022
    Default Keeping the 6L80E
    Quote Originally Posted by Kermit View Post
    OK - Have decided to stay with the 6L80E as it will be better for highway use and have found a transmission shop that will warranty a custom built trans to take 900 crank horsepower.
    Yes I am changing to a true track rear end with 3.47 gears
    Will also be adding nitrous to the motor when I get the trans and rear done.
    Thanks for replying.
    Regards Rob.
