Results 1 to 5 of 5
Thread: Tire Pressure System Failure
    Jun 2013
    Default Tire Pressure System Failure
    Tire Pressure System Failure Warning. The tie pressure system set a warning like I have low tire pressure but all 4 tires are t reading anything and have proper tire pressure? Any one have this happen and have any ideas as to what is wrong. I was thinking I’d just take the car to a tire place and have them replace the valve stems and sensors.
    1985 Buick Grand National w/87 drivetrain
    If one sensor dies, the whole thing kinda stops working. It's not the most user friendly thing, because then you need an OBD scanner that does TPMS to tell you which one. Or maybe a TPMS battery scanner like this might tell you.
    https://www.amazon.com/Autokcan-Rele...a-824413969640
    Jan 2010
    Southern New Hampshire
    AND... once you are at the point where one of the sensor's (battery) has failed, it is only a matter of time before the other 3 follow suit. I was in the same situation a little while back.
    Creature Comfort:
    XM & OnStar out/CoStar BLUESTAR in
    Show:
    Go/Whoa:
    VMS ECM/TCM tune, Vararam, HSRK, ARH 1-3/4" LTH, HFCs into stock mufflers, Mobil 1, Pedders Street 1 kit, front Brembo's, PPV struts & shocks
    LSA Supercharger (base), Rear PPV shocks, Rear Brembo's, Russell rear brake lines, Staggered Camaro 20's with Holden centers, Morimoto HID's, wireless Aux input for tunes off of the cell phone.
    VIP Member MongosG8's Avatar
    Connecticut
    [QUOTE=J Wikoff;626140]If one sensor dies, the whole thing kinda stops working. It's not the most user friendly thing, because then you need an OBD scanner that does TPMS to tell you which one. Or maybe a TPMS battery scanner like this might tell you.
    Exactly!! One will be out but will show all 4 not working. ]
    I agree on the OBD sensor. I purchased this a few years ago. It was 6.99 on Amazon. Saves you a headache
    Quote Originally Posted by 52WASP View Post
    I agree. once one goes the others follow suit. I learned from experience years ago.
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
    I had to replace one a couple years ago. The other three are still working fine. It's cheap enough to replace one at a time as needed. And it's not like you can't drive the car while one or more are dead.
