Results 21 to 30 of 38
Thread: Looking for sub recommendations on stock amp
  1. #21
    VIP Member MongosG8's Avatar
    Connecticut
    IM glad you figured out the issue with the door speakers. I had a similar issue and ended up soldering mine. As for the subs they are not Polk like I thought they were they are the Alpin 8 inch 2hm subs. They work great!
    Im the type that likes quality of sound. I don't care how loud they go I just want quality. These were perfect. I think I paid 200 bucks for the pair.
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
  2. #22
    A 4 ohm sub will work, but all else equal will only be half as loud as the stock sub. I think you'd be pretty unhappy with it
  3. #23
    Member SpeedDemon G8 GXP's Avatar
    Jan 2021
    Fort Worth
    So are you saying that due to them being 4 ohm they are gonna be worse then the stock subs???? I'm not looking for this massive improvement or anything, just something that sounds a little better. Its going off the factory amp so i'm not expecting a lot but I figured it would be at least a little better.
    2009 Pontiac G8 GXP: Red, manual, LT1-S Twin Disk Monster Clutch, CTS-V 19 inch wheels for that extra grip, cam, exhaust and headers. 451 RWHP 1 of 61
  4. #24
    They will be very quiet and you won't be happy.
    Relevant equation:
    Power = voltage squared divided by resistance (p=v^2/r)
    Resistance is the ohm value of the sub. The amp provides voltage in a way that is independent of the sub ohm value.
    So a sub with twice the resistance will result in half the power.
    Then there is sensitivity of the sub. It measures decibel output per watt. I think measured at one foot away, but not really relevant.
    Subs are normally around 80 to 90 db per watt per foot.
    Power is measured in watts.
    Put it all together, a 4 ohm sub is a lot quieter than a 2 ohm sub and won't make much noise at all. Stock subs are 2 ohm. Get a 2 ohm sub so the volume level is about the same.
  5. #25
    I should also have said, a dual voice coil 4 ohm sub will work like a 2 ohm sub.
  6. #26
    Jan 2021
    Fort Worth
    So I am returning the JBL's and just bought the Rockford Fosgate p3sd2-8 2-ohm DVC subs. I looked at a lot of reviews and these are ranked in the top 10 on several websites so hopefully these will work. If not then I give up. lol
  7. #27
    Ok. A 2 ohm DVC sub will act like either a 1 ohm or 4 ohm sub. I would bet the amp won't handle a 1 ohm sub very well.
    I linked the 4 ohm DVC version above. DVC means dual voice coil. When you wire it all up, the resistance (aka impedance) is either twice or half the value. A little confusing, I know, but it gives options for those that change things around. You maybe could just wire one of the voice coils to have a 2 ohm setup, but I don't know if that is recommended. It's also a waste of a voice coil.
  8. #28
    Jan 2021
    Fort Worth
    OMG!!! I am so confused......I have no idea what I am suppose to get then. Not 4 ohm but not 2 ohm either. I though 2 ohm was what I was suppose to get.......my brain is fried.......What did you mean by "you linked the 4 ohm DVC version above". The JBL's are single, not DVC.
  9. #29
    I linked the 4 ohm dual voice coil version of the Rockford Fosgate 2 ohm DVC version you bought. Here it is again.
    https://www.sonicelectronix.com/item...-Complete.html
    You need 2 ohms total resistance/impedance per speaker. So that means a 2 ohm single voice coil sub, or a 4 ohm dual voice coil sub. Dual voice coil means there are two coils of the listed ohms. It will have 4 terminals instead of the 2 terminals a single coil sub would have. Wire each one parallel and the amp will see the 2 ohm load that will work best.
    When you have 2 voice coils, the result is half the listed resistance if you wire them in parallel. 4/2 = 2. You might have to Google it and watch some YouTube on wiring a DVC subwoofer. It is not hard, just takes a couple extra minutes.
  10. #30
    Jan 2021
    Fort Worth
    OK so I think I know what you mean now. I looked at the stock subs and there are only 2 wires. Obviously a positive and negative. If I get a DVC 4 ohm sub and there are 4 terminals how do I wire that to the existing wires that are there, Just one positive and one negative? Remember I am only using the stock amp. Or do to the fact that I am going to be using the stock amp and the existing wires, which are only 2, means that I can only do a single SVC speaker?
