Results 1 to 1 of 1
Thread: G8 Airbag Light Blinking, No Codes (anymore), Help???
    Aug 2017
    Default G8 Airbag Light Blinking, No Codes (anymore), Help???
    So I got this lower mile G8 GT and am having trouble getting a blinking airbag light to go away. It's just the red airbag icon blinking, not on display read out. When I initially scanned the codes with my (knock off) tech 2 I bought to fix this issue I got a few codes for passenger presence sensor. After inspecting wiring I found the locking clip on connector to passenger presence sensor was missing causing it to back out just enough to lose connection. So I pushed it in and taped it up to test it out. It seems it fixed it but red airbag blinking light is still on??? Here are the codes from initial scan before I fixed connection, I don't think the non passenger presence codes are relavant to airbag light but maybe I'm wrong?:
    B101D -39 : Some kind of instrument panel Cluster fault (unknown DTC) -- I've read something about radio on this one. Current Fault
    B1045 -04 : Radio Fault - Audio Output 3 Left Rear Circuit Open - Current Fault
    B0081 -71 : Supplemental Inflatable Restraint System - Passenger OPresence System 1 Invalid Serial Data Recieved - Not Current Fault / Passing Tests Now
    B0081 -5A : Supplemental Inflatable Restraint System - Passenger OPresence System System 1 Plausibilty Failure - Not Current Fault
    U0140 -00 : Instrument Panel Cluster - Lost communication with BCM - Not current fault and not in history (not sure why this one is in there, maybe from dead battery?)
    Well, if ANYONE could point me in the right direction here I would greatly appreciate it!!!
    I'm in Houston is anyone is around here and wouldn't mind taking a look either. I'll pay for your time, just don't want to pay dealer prices.
