Results 1 to 4 of 4
Thread: Parting out 2 G8s
    Feb 2016
    Default Parting out 2 G8s
    Hello all, I’m in the middle of gutting my G8 GT and moving it over to a base donor. Basically the GT interior is moving over and most of it’s exterior. Painting the rest of the it the MGM to match the pieces. If anybody is looking for something in particular I can see if I have it and set it aside. I’m not really looking to profit from this. Any money would help but it’s mainly to help others.
    I also have 2 sets of wheels, V6 wheels and the stock GT wheels. Both have nothing major and mainly for those who want/need a set. Tires are shot on them.
    Finally, I have 3 fire hawk wheels available. I need to clean them but they looked like they don’t have paint/clear chipping, no dents or chips. I can verify and split if needed. 2 have Goodyear RS wheels with less than ~10k miles on it. One wheel the tire is chewed up a little so I wouldn’t count it. I’m looking for $400 for the complete tire/tpms/wheel caps
    $300 for the one with the bad tire.
    I’d post pictures but with everything going on, PMs and I’ll send what people are asking for.
    Thanks,
    Andre
    Friendswood, TX
    Might you have the drivers side lower seat panel?
    VIP Member MongosG8's Avatar
    Connecticut
    Hood Scoops/hood vents?
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
    Member mdg8gxp's Avatar
    Nov 2009
    Baltimore
    I'm looking for the floor console trim panel, #92235389 Shift Panel. Do you have one?
    __________________________________________________ ____________________________
    RotoFab - 1.75" Kooks - Jet Hot - Corsa - BMR Bushings, Sway Bars, Toe Rods, Trailing Arms - UPR
    Koni Sports- Forgestar F14 - General G-Max - RPM Engine & Trans Tune
