Results 1 to 5 of 5
Thread: Eibach pro kit springs for Chevy SS ?
    Senior Member 1nastyss's Avatar
    Mar 2014
    Greensboro,NC
    Default Eibach pro kit springs for Chevy SS ?
    Will eibach's lowering springs from a chevy ss work/fit for a g8 gxp?
    2009.5 G8 GT
    Mods: Kooks mids, Solo mach unbalance, rotofab cai, pat g tune, haas front splitter, cts-v wheels, 3.45 otw
    Beyond Help Slizzo's Avatar
    Newington, CT
    Not sure. Supposedly the only things that carried over are the door skins and roof panel from VE to VF.
    supposedly the connection on the SS struts and it's spring saddle are in different locations to accommodate a 20 inch wheel base. which renders the factor sway bar and links possibly unuseable.
    I've also heard the bore diameter at the strut mount is different but don't know for certain. Supposedly the SS and Camaro have similar suspension pieces - but they don't cross to the G8. Which is why you see PPV to G8 packages but not SS to G8. Might be worth asking the seller to take some measurements before you buy.
    It might be an easy retrofit with say custom sway bar end links or such.
    Do you mean 20 inch diameter wheels?
    2009 LR G8 GXP - M6, Roof, Onyx/Red Interior
    Oct 2022
    Answering the OP question
    Fit? Yes BUT
    The Eibach #3895.140 for the SS lowers the car 1.2" front and 1.3" rear
    The Eibach # 38137.140 for the G8 lowers the car 1.0" front and 1.0" rear
    Also GXP25 is correct that the the sway bar and links from the SS are unusable on the G8
