Results 1 to 8 of 8
Thread: Drop in fuel pump?
    Aug 2011
    South Padre Island Tx
    Default Drop in fuel pump?
    I've tried searching but i haven't been successful. Im looking for a drop in fuel pump for the stock bucket. I know i can get a whole ZL1 module but i don't really want to go that route. I've seen the TRE265 Treadstone pump. But it doesn't say its compatible with E85. Deatschwerks DW300C 9-309-1008 is a direct fit for the GTO much like the TRE265. The only difference is the DW300C flows 340LPH and is e85 compatible, I am going to call in and ask if it is PWM compatible. Has anyone ever tried to install this pump? I recently ordered a Lingenfelter Bosch 350 but it was way too big for the stock bucket. My G8 GT is a cam only setup at the moment on 93 octane. But i already have the flex fuel sensor wired up and installed. Plus i have a LS3 awaiting to go in along with a Nitrous Outlet plate kit. So i know i will be needing a lot more fuel.
    9-307-1026.jpgActually the one you want is the 9-309-1026. This way it comes with the pre filter that mounts on our stock pump.
    Aug 2011
    Thank you GT drew, I bit the bullet and went ZL1 with a vaporworxx kit
    Aug 2020
    Arkansas
    Does anyone know where I can get an OEM part number for the 90-degree elbow for my 2008 G8 GT fuel pump outlet. I sliced into the fuel line while installing the new cover plate under the rear seat. I'm thinking that it's 11.8mm with a 13mm nylon hose outlet. Thanks! Ken
    Apr 2022
    Quote Originally Posted by tellpathic2 View Post
    BITMAIN, GOLDSHELL, INNOSILICON MINERS 2022 IN STOCK
    All equipment will be shipped from our warehouses in Shenzhen China. Additional shipping charges apply to orders shipping to international destinations.
    GOLDSHELL KD2 MINER PROFIT 27$ DAY
    https://apextominer.org/en/product/g...s-second-hand/
    BITMAIN ANTMINER S19j
    https://apextominer.org/en/product/2...s-second-hand/
    WORLD DELIVERY 3-7 DAYS
    Sep 2009
    VT
    https://almperformanceanddesign.squa...nsrx2o5qsjhl90
    Sport /Premium
    Aug 2020
    Arkansas
    Does the administrator know that you are trying to sell products unrelated to G8 blog? I believe that you are in violation of your membership.
    Sep 2009
    VT
    How is it unrelated? Which 90 are you referencing? If on top of the hat, it's molded as part of the hat and not replaceable. My link points to a solution. nothing more.
    "This hat will directly fit second gen Cadillac ctsV, the alignment tab can be modified for zeta platform applications including 5th gen Camaro, GTO, SS Sedan, G8; however module compatibility can only be confirmed with the twin pump ctsV unit."
    BTW, works perfect in my G8.
    Sport /Premium
