Results 1 to 4 of 4
Thread: Need Help
    Sep 2015
    Default Need Help
    Any of you guys lowered with bmr parts. Such as there lca, trailing arms and toe Rods. I was lowered and aligned. Then I switched out the lca tailing arms and toe Rods. I've been to multiple alignment shops and they can't get aligned. Last time they needed a camber kit. Got it and it didn't Help on the rear. They said the eccentric will not move. I tried and it will only move quarter or so either direction. My guess is the lca are designed for the camaro and wasn't tested on these. Any ideas
    Does BMR say their caster is adjustable? As far as I know, it's fixed. To add caster to my Pedders lowered G8 caster bits were added to add positive caster. What is the alignment shop saying the caster is?
    Sep 2015
    Camber is my issue
    An aftermarket, lower control arm cam bolt is needed. They offer more adjustment than the stock bolts. If you stock bolts are seized , that is your problem. Have them put anti-seize on the bolt so it doesn't sieze to the bushing again.
