Results 1 to 10 of 16
Thread: steering wheel controls stopped working
    Default steering wheel controls stopped working
    I don't know how common this is but I figured I'm post it here.
    So my LH steering wheel controls don't function - which wouldn't normally be a problem but it also means I can't turn off the DIC message for my low tire as that stays on the screen. And I can't get to menus either.
    started acting up a month ago - now it doesn't work at all. Otherside is fine.
    Is this common?
    As I understand it they are CAN Buss modules - and fairly easy to replace. SO I'll do that first I guess. My other thought is clockspring - since they don't light up either and haven't for a while now.
    When my clock-spring failed, it was a progressing snowball of dysfunction. If I remember right, the right side kept working. At least initially anyway... I'd have to look back at my old posts. There was a while where turning one way would cause the radio to switch stations.
    That's exactly what mine was doing.
    Is the clock spring repair expensive/difficult to do?
    The part is a couple hundo. There is some sort of calibration to be done after install, probably VIA tech 2 or something. I had the dealer install it after I found the best price I could online. Physical install didn't look too bad. I'd done the steering wheel previously which went find and the clockspring isn't much further in. I think the dealer install cost about the same as the part.
    so 700 dollar repair. I wonder if my scan tool will do the calibration.
    Oh question did it make the car undriveable? I mean not having the menu function is annoying as all get out - but doesn't really affect the car function.
    Too many projects.
    Detroit, MI
    Should not have to re-program for a vehicle that was not in an accident etc.
    The SAS doesn't always need to be reprogrammed but I can see that issue if it comes up.
    List is $500 on the coil...I bought one for less before.
    I think the part you need is 92234063 if that is the case, but i can't confirm if there is more than one available.
    2009 Saab 9-3 Combi / 2.0T
    I think my total spend was around $500.
    N.O.LA
    So, other than being in an accident, what causes the clock spring to fail and how common is it?
    JAM
    Too many projects.
    Detroit, MI
    Probably internal wear or a connection in the wheel came loose. But that is rare.
