Both Front Windows Don't Work, But Rear Window Does Work! What the @#%
SMH...Can anyone help me with this? Both front windows will not operate, but the back ones will!
I have read many post on the forum about this issue, and I have replaced the window switch and still the same thing happens.
Does anyone have any suggestions? Window motors maybe...could both windows good out at the same time?
Thanks in advance!
Problem solved...the power door lock connector was not fully connect to the switch, once that was done, the front windows started working! I am guessing the front two window switches are running off of the same circuit as the door lock, or it is used to complete the circuit. Either way, I as very happy that it all works!
- You may not post replies
- You may not edit your posts
Forum Rules
