Results 1 to 4 of 4
Thread: Can’t remove key
    Nov 2018
    Default Can’t remove key
    08 g8 need a little help. The car will will crank and run but it will turn off to the on position. I know it sounds stupid. The key will turn to on position. The car will shut the engine off. But the key won’t turn to the last position. No codes no blown fuses but no power to fuse f13 f14 f15 f16. Any ideas
    Maybe run a jumper to those fuses for power. Have you checked to see if either side of the fuse is shorted to ground?
    Check this thread
    Check R8 relay. Drivers foot well.
    Arlington Heights, IL
    You should also find that your outside mirrors will not work while the key is stuck in the ignition. Ask me how I know....
    It will take 30 seconds to replace R8 and you will be good to go.
    PBM #608 of 888 -- All Stock!
