Results 1 to 10 of 10
Thread: Best Headlight bulbs for stock system?
    Nov 2017
    IL
    Default Best Headlight bulbs for stock system?
    G8 Team,
    When I bought my 2008 G8 GT in 2011, someone had installed an HID system. It was 'ok', but I got stuck in a situation and had to have them all removed and stock installed.
    The stock low beams are dangerously dim, no exaggeration. The high beams are friggin' amazing. The installation was done at a dealership about 5 years ago, but the low beams have always been dim since then.
    My question to you all....what headlights could I buy at my local Autozone/O'riellys/Advance/Walmart/Napa that would be a noticeable positive improvement on whatever bulbs the dealership would have installed?
    Your input is MUCH appreciated as this has been on my list for years now.....
    Thank you!
    BamaZ28
    Something sounds not-right about what was put in as stock when it was demodded. I thought the stock low beams we're pretty darn good. I did change to some LEDs for the look, and they are pretty good too, but I haven't seen them on Amazon in a while. There are Philips bulbs that are upgraded H11s, I can't think of what they are called at the moment.
    Senior Member JAFO's Avatar
    Sep 2013
    Newberry, SC
    Best thing you will probably find at a local store, IMO, would probably be Sylvania Silver Star Ultra. Not cheap, probably gonna run around $35 each.
    --Brian--
    2009 Pontiac G8 GT
    2008 Chevy Impala SS--Traded 4/1/2021
    2016 Dodge Challenger R/T Plus
    2001 GMC Sierra
    GODSPEED CHARLIE!!! R.I.P.
    Beyond Help tchr49's Avatar
    michigan
    Quote Originally Posted by JAFO View Post
    Been my experience that Ultras do not have a good track record when used in systems that use DRL’s.
    Feb 2011
    Latham NY
    Read the Ultras have a shorter life than the regular SilverStars which are shorter lived than regular halogens. So went the regular SilverStars which have better output than the stock halogens.
    michigan
    The Ultras seem to last about six months. One will go, and then the other. They are super good about warranty though.
    If you can get at the light easy, maybe you want to put up with the hassle. If you have a front bumper removal to replace a bulb, stay clear.
    Member chevybernie's Avatar
    Aug 2017
    In my G8 i bought Bulbs from Ebay. Itīs a dealer named " argocity". They have lots of bulbs. Standard bulbs with xenon gas and 100watt. I have all weather rainbow bulbs. I think, light is much brighter than normal bulbs. I have it too now in my winter car. Itīs a Kia Sorento. More light too. Only, the shine changes from pink in the middle, to green and white outside on the road. - But it looks good.
    Senior Member white lightning's Avatar
    NC
    I'll ya what I did: I bought a couple of high beam bulbs and modified them to fit in the low beam side. Works great! I've done it on my '02 camaro and '90 pontiac too. makes a big difference! The projectors cut off the light so they don't blind oncoming traffic. And even if they're aimed a little high it doesn't matter cuz most headlights are blinding now. You take a dremel with a small grinding stone attachment to grind off the keyways inside the lamp connector and then grind off half of the top metal locking tab (the one opposite the connector). It's the left side as your looking at the tabs. Only grind off half of it! Don't grind off the entire tab cuz then it won't lock into the headlight correctly. I think I learned this on you tube so you might do a search.
    '09 G8 GT, PBM, premium, sport, roof
    PCM Trans cooler, Vararam, ARH 1 3/4, Dyno tune
    Modified: 12.832, 109.26mph, 1.988 60'
    Stock: 13.523, 105.94mph, 2.038 60'
    The brighter blueish bulbs also don't last as long so keep that in mind since they're a PITA to replace. I'd go with some Morimoto HID or LED bulbs personally. You get what you pay for, for sure.
    Jan 2010
    Southern New Hampshire
    I say Morimoto HID as well. I put Morimoto HID's (with the 50w ballast upgrade over the 35w) in my '14 Sierra- which had shit headlights stock. Without a doubt, THE best mod I have EVER done to a vehicle. Now, I did have a bulb burn out prematurely due to the DRL's (until I spent 6 minutes and removed the spring from the switch assembly), and The Retrofit Source (where I bought them) was nothing short of AMAZING in getting me a new bulb in the mail, PRONTO. I also installed Morimoto LED fogs in the G8 awhile back (based on a thread on this forum)- those are great too. And when one burnt out, again, TRS was ON IT getting me a new one in the mail.
    There is a Morimoto HID upgrade in my G8's future- and TRS will be where I buy from.
    Creature Comfort:
    XM & OnStar out/CoStar BLUESTAR in
    Show:
    Go/Whoa:
    VMS ECM/TCM tune, Vararam, HSRK, ARH 1-3/4" LTH, HFCs into stock mufflers, Mobil 1, Pedders Street 1 kit, front Brembo's, PPV struts & shocks
    LSA Supercharger (base), Rear PPV shocks, Rear Brembo's, Russell rear brake lines, Staggered Camaro 20's with Holden centers, Morimoto HID's, wireless Aux input for tunes off of the cell phone.
