Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Why are my struts moving ?........ALOT
    Senior Member GXP-G8's Avatar
    Apr 2014
    Clovis, NM.
    Default Why are my struts moving ?........ALOT
    https://youtu.be/rl3rEly16qA
    What is happening at the top that it moves that much ?
    Help !
    09 G8 GXP Auto, 4dr GTO 13.60@104.2 6177 DA.... tvs2300 13.2@110.2 spinnig all the way !
    07 G5 GT 2.4T Auto, Baby GTO 13.20@106.4
    @ 4200' in the sky !
    Quote Originally Posted by andrewbrooks87 View Post
    towing stuff with cars is cool !
    Beyond Help Slizzo's Avatar
    Newington, CT
    Have they ever been replaced? Many of these cars had strut bearings and bushings wear out prematurely from the slow boat ride from Australia where they were strapped down very tightly to the boat.
    2015 White Hot Chevy SS - Sunroof/Spare/Stick - BTR Stage 3 cam, headers, intake *Traded 11/11/2023*
    2018 GMC Sierra Denali 1500 - 6.2L, Ultimate Pack *Turned in 4/13/2021*
    2016 Jungle Green Metallic Chevy SS - Sunroof/Spare/Stick *Traded 2/1/18*
    2011 Radiant Silver Metallic CTS-V Wagon - Corsa Axleback, AirAid Intake *Traded 7/7/16*
    2008 Panther Black Metallic G8 GT * Sold 6/10/14*
    Apr 2014
    Clovis, NM.
    Brand new set of Super Pro's installed, blue ones.
    New struts over a year ago with purple Super Pro's installed by a friend,
    car seemed a bit loose on rough roads and got worse. I noticed the strut towers moving one day so I ordered a new set just in case.
    Took struts out and nothing looked odd or out of direction, so I replaced them any way.
    Above video is what I have now with new mounts
    Addicted Member
    Sep 2011
    that movement is when you terming the steering wheel?
    Administrator Chewy's Avatar
    Bettendorf, IA
    That's totally normal!
    Beyond Help Napalm's Avatar
    Mar 2011
    Memphis TN
    what were you doing to make it move like that - turning the wheel or pushing down on the chassis?
    If turning the wheel some movement is going to happen but I don't believe it's that much.
    First thing that comes to mind is your struts aren't the right length for the car/ride height and you don't have enough
    Second thing is that the washer stack at the top where the mount meets the body isn't setup right and the nut isn't tightened correctly. If not stacked right I think (it's been a while since I had mine out) you could get a condition where the tighten up the second nut but the washer and body washer interfer and snug up without capturing the chassis tightly.
    Can you turn the top nut with ease? in either direction
    Apr 2014
    Clovis, NM.
    Turning the steering was what was making it move.
    The struts I bought from Pace, GXP FE3 strut and shock package over a year ago.
    The mounts are super pro with updated washers, both are installed correctly.
    You can NOT turn the top nut except for the bit of spring loaded tension.
    Old set did same as this set, guess I'll look at tie rods, this thing steers like crap, wondering around
    I just don't know
    Mar 2011
    Memphis TN
    maybe there's a piece missing - or they aren't clocked right.
    It's been a while since I did it but I vaguely remember there is a Left and Right and a certain positioning for the spring top such as to make sure it seats properly in the pockets. It's something to the affect of looking at the strut with the knuckle flanges behind it - spring, boot etc on - then the top plate has a orientation with respect to the strut body and when you put on the nut and torque it to hold the assembly it has to be in this position or it doesn't fit up under the car correctly. somewhere on this board or the other g8board there is a thread with some example pics. Once you see it it will look slightly obvious. Do they pop when you turn - usually when someone got it clocked wrong it would make popping noises
    did you own the car since new - where there any modifications?
    It needs to come back apart to see the setup and check it that's no where near right.
    Apr 2014
    Clovis, NM.
    No pieces missing, W notch in top spring plate is facing the engine, spring is aligned with the factory marks on spring and top seat.
    No popping or noise of any kind.
    Car was totally stock at 50,000 miles when I bought her.
    hmmmmmmmmmmmmmm
    Quote Originally Posted by Chewy View Post
    Looks completely normal to me. Mine looks just like that. Pedders Street II and new bushings installed after the turbo fire.
