Results 1 to 5 of 5
Thread: Changed input/output speed sensor now no gear
    Mar 2014
    South Fl
    Default Changed input/output speed sensor now no gear
    I changed my input/output speed sensor becUse of codes I got a few times and now the linkage moves the trans outta park but that's it. No gear engagement or even showing anything other than park on the display. I can roll it when I shift outta park but that's it. The job was simple, I dropped the pan, disconnected the main connector, dropped the valve body then swapped out the sensor/harness, reinstall. Everything went smooth. So I went back in and rechecked everything again and installed the old sensor, still nothing. Disconnected the battery for a while, nothing. No codes.That's the only pic I took, right before I took out the six bolts for the tcm/valve body and then removed it. Swapped the sensor and didn't touch shit else. I even kept the pan full of fluid when I dropped it and just topped it off after reasembley. Please help, any ideas?
    No codes? Pinched wire or pulled wire in a harness.
    I looked at all data and didn't see any programming that needed to take place.
    Did you disconnect battery during procedure?
    If not maybe double check all fuses.
    Mar 2014
    South Fl
    Yeah, I didn't disconnect the battery during install. Felt like a fool after. I checked fuses, all good. I kinda tested the main plug, with the engine running I disconnected and reconnected the plug and there was definitely a change and warning lights came on, abs, traction control...I then cleared them so the harness/plug is communicating.
    Mar 2014
    South Fl
    I got it. Not sure about the terminology but the valve body "range selector" wasn't connected to the linkage. In the pic, the orange arm has to connect to the linkage. So simple.
    Oh my gosh. Glad you found it, something so simple.
    Hopefully no more codes!!!
