Results 1 to 2 of 2
Thread: DOD Delete question
    Apr 2018
    Default DOD Delete question
    Hey all
    I知 about to do a DOD on my 08
    Since the heads have to come off, Id like to get them milled to bump up the compression.
    My question is for those that know for sure,
    How much can the heads be milked safely for the most power gain.
    I値l be running the stock LS9 Head gaskets, unless I can bump it up using head gaskets alone, and if so which gasket would I use.
    Also if milling the heads, what pushrod length would I need?
    Thank you in advance
    I値l be using the Brian Stage II N/A camshaft if that helps
    I would direct those questions to Brian tooley racing - they would tell you what compression would work best with that cam.
    Also, they will spec pushrods for you. If not, get a comp pushrod length checker. Ls7 lifters are notoriously picky, you want as perfect of preload as you can get.
