Results 1 to 10 of 10
Thread: Stuck Key and Ignition Circuit Diagram
    Apr 2018
    Default Stuck Key and Ignition Circuit Diagram
    Anyone have an ignition circuit diagram for a 08 G8. Having "stuck key problems" and wanted to understand all interconnection devices for starting, locking shifter, etc. Shifter is NOT locked in park, as a matter of fact, it will pull out of park just sitting. But cannot turn key to OFF position to remove. Can start it. Putting it in park will activate the door unlock and the indicator on the dash says it's in park. That tells me the Shift Lock Sensor at least sees that. Brake pedal position sensor does not seem to cause relay to click near the shifter. Saw this in a video. Brake lights work.
    Trying to figure this out so I don't get reamed at either the dealership or a shop.
    Any suggestions?
    Yoire saying you can move shifter without pulling the "trigger" button?
    Apr 2018
    Sorry. No have to pull the button, but do not have to apply brake. Button pulls regardless.
    Apr 2018
    Thanks for the PDF's. Those will help. Just trying to narrow this down. Could be as simple as a faulty ignition switch, but was trying to make sure all switches were lined up to let the key go back to off/lock position and be removed. Had transmission worked on in January and was also leaning toward faulty neutral safety switch. But problem just now surfaced.
    Auto trans shifter pinout.
    Auto Trans Shifter Pinout.pdf
    In order for the key cylinder to be unlocked, you've gotta pass ground from pin 3 to 6, I believe.
    I am not totally sure how the cylinder acts, however, if this was simply an interlock issue then maybe you're able to actually turn the key to OFF, just not remove it.
    it sounds like you've said that you can't turn it to the off position, however. But again, as you mentioned, the car is seeing the trans as being in park evidenced by the doors unlocking. Odd for sure.
    Try this, vague, but it might help...
    Shift lock troubleshooting.pdf
    Apr 2018
    Thanks again. All of this is electronic is it not? A friend(great mechanic), over the phone said something about a cable to the ignition(mechanical), from the shifter. He has not messed with G8's and is probably used to other systems. Said the release through the cable could be binding. Just a question. I'm going into the shifter now.
    All electronic, relays and solenoids. The BCM is involved, as well.
    I would use that last document I posted for the troubleshooting techniques and test it the way they say to. They specifically are talking about what leads to not being able to put the key in the OFF position, much less remove it.
    Good luck!
    Apr 2011
    DFW, TX
    When I had intermittent key stuck events I tested relays, fuses, less costly electronics and in the end it was the ground signal switch on the shift assembly. Good luck to you and I hope yours is simpler.
    09 White Hot G8 GT
    Tuned by Rick Crawford
