Results 1 to 7 of 7
Thread: LSA swap at 140k?
    Nov 2015
    Default LSA swap at 140k?
    Hi all,
    I did a cam/head rebuild 15k ago when my DoD lifter failed. I was surprised how clean the cylinder walls were compared to some of the older 350 stuff I've rebuild. Well I'm bored with the power and about to start ordering stuff for a LSA build.
    Am I being foolish putting a blower on such a high mileage engine? It does not burn oil and holds great pressure. I want to get a ATI pulley so I can go higher in the future but I plan on keeping everything around stock boost levels until I do a engine swap next winter.
    Stuff I plan on doing now;
    Squash fuel system
    LSA swap
    Axles
    rear BMR suspension.
    Stuff to be done next summer pending it holds together;
    Engine
    Trans
    Go for it. Should be fine as long as you stay away from moon boost.
    Dec 2012
    However, moon boost is where the glory is.
    Jan 2018
    How many lbs to get to moon boost?
    Beyond Help tchr49's Avatar
    michigan
    Depends....
    Just remember, forced induction is your friend
    TX
    Since you're doing axles and fuel pump you can go fairly crazy. I've read the stock rotating assembly can do 750 no problem.
    michigan
    Lotta boost is gonna make heat. Are you planning on staying on 93, or looking at other options?
