Results 1 to 6 of 6
Thread: traction control off at start up.
    Member Rubberman's Avatar
    Oct 2016
    Evansville, Indiana
    Default traction control off at start up.
    as soon as i start the G8 and it runs the tests it immediately shows traction control off on the screen. Pressing the button does nothing. scanning the computer shows no codes at all. any thoughts?
    i use to have an the code - P0161 which is the brake pedal sensor. when driving the brake light would go off after releasing the brake pedal unless i tugged up on the pedal. if i didn't catch and drove with the brake light on then traction control OFF would pop up on the screen and then give me the code C0161. but the past could days its automatically shows up after start up.
    Jan 2018
    Did you ever figure this out? I got the same problem. Thanks
    Too many projects.
    Detroit, MI
    Is the ABS light on?
    I'm going with the typical broken wire in the sensor harness in the rear otherwise.
    2009 Saab 9-3 Combi / 2.0T
    Apr 2017
    Sterling, Virginia
    I have the same problem with my G8 and it seems to happen on really hot days with my G8. I have never had an ABS light in conjunction with this though so I am curious what everyone else is experiencing.
    Apr 2017
    Sterling, Virginia
    Quote Originally Posted by MIEngineer View Post
    What is this harness/wire that you speak of? I haven't found anything in my searches so far. What I do have myself is a C0196 5A code as read by my TechII but I am not sure where to go from there.
    Apr 2017
    Sterling, Virginia
    Never mind on the harness question. I found the info on that and I don't have that code (C0045) so I am still stuck.
