True Forged wheels for sale w/tires 20x8.5f, 20x10r
For sale set of True Forged brand 20 inch wheels with Continental DWS06 tires.
Front wheels: 20x8.5 35mm offset
Rear wheels: 20x10 52mm offset
Original fitment was Pontiac G8. Will fit G8, Chevy SS, 2010-present Chevy Caprice, Cadillac CTS, 5th generation Camaro, any of a number of GM car models with 5x120mm wheel bolt pattern (educate yourself on your offset requirements), any of a number of BMW car models with 5x120mm wheel bolt pattern (educate yourself on your offset requirements).
Tire sizes are 245/40/20 front, 275/35/20 rear. One front tire leaks from the bead, and one rear tire is unusable. Plan on having to replace both these tires. Finish on the wheels are brushed aluminum centers, and a semi-polished/semi-brushed on the barrels.
Wheels come with laser etched Pontiac center caps, as well as True Forged logo'd center caps.
Make offer.
How much shipped to 33196? Would you sell just the wheels without the tires? Would the fronts fit over v brembos?
Thanks for the q's. Fronts fit over brembos with a thin spacer, which I'll include, forgot to mention this. I had 6 piston brembos and they worked great with the spacers, I believe they are 5mm. Tires go with the wheels, I don't have any use for them. If you don't want them tell the tire shop to trash them. It's looking like shipping to that zip will be $250.
Ok so how much shipped and everything ? You didn't put a price
Sorry, I thought I had updated this. They sold sometime last spring.
Sent from my FRD-L04 using Tapatalk
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
